    So I have the yellow wired stepper Pic A Below
    and I'm making the plugs for this board and its wired with the black one.. Pic B below
    do I wire the plug to yellow wire diagram ? I know it sounds like a n00b question but I thought its better to ask than set fire to something lol
    Ralph Waldo Emerson
    Lives in East Lothian, United Kingdom. Last Activity: 13 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 375 times, giving thanks to others 9 times.
    As long as the correct coil pairs are matched, the only difference it'll make is what direction the motor runs.
    Doddy's Avatar
    Lives in Preston, United Kingdom. Last Activity: 4 Weeks Ago Has been a member for 9-10 years. Has a total post count of 1,364. Received thanks 188 times, giving thanks to others 66 times. Referred 1 members to the community.
    Okay, I've spent 2 minutes on the Makerbase website and given up - have you got instructions for the board, and in particular which are the A+/A- and B+/B- terminals on those 4 way plugs?
    If so - it's easy - work out the coil pairs on the stepper? If you have an Ohm meter (DMM etc) then measure which pair of leads has ~1-3 Ohms resistance between them - of the four wires, there are two pairs each with that low resistance. Then you need to wire ANY pair to the corresponding A+/A- pins (doesn't matter which way around). Wire the OTHER pair to the B+/B- pins - again, doesn't matter which way around. There's a 50/50 chance that the motor will spin in the wrong direction - then swap the pins on ONE pair only (so swap A+/A-, for example).
    If you don't have a meter... buy one. Or short two wires on the motor together (with nothing else connected, of course!) - if you find two that makes it more difficult to rotate the motor by hand - you've found a pair. Confirm by shorting the other pair with a similar increase in resistance to rotation.
    If it makes you feel better - you're not going to burn the house down. The one thing you must do, however, is avoid removing the stepper wiring when power is applied - it's a good way to destroy the drivers (read up on collapsing EM fields)
  5. The Following User Says Thank You to Doddy For This Useful Post:
  6. #4
    Its the red an black wire that always throws me, I keep thinking its live/earth but of course its just polls. It worked wired as in the diagram.
    Ralph Waldo Emerson
  7. #5
    Quote Originally Posted by Fivetide View Post
    Remember electricity does not care about the colour. In Spain the black wire is the live phase, where as here it used to be red now it it brown
  8. The Following 2 Users Say Thank You to Clive S For This Useful Post:
  9. #6
    I pinned one of them up with single puponts in case it it didn't work but worked fine first time
    Ralph Waldo Emerson
  10. #7
    In the USA they use black for positive and white for negative. You find a lot of imported 12V stuff for cars and caravans in Australia like that which throws any ex-pom who assumes that black is still negative and only the positive colour has changed!
  1. Hybrid stepper wiring
    By gregors in forum CS-Lab (CSMIO)
    Last Post: 12-12-2020, 03:48 PM
  2. Stepper Motor Wiring
    By ravihotwok in forum General Electronics
    Last Post: 26-07-2017, 10:41 AM
  3. Limit Switch wiring question
    Last Post: 03-06-2015, 02:11 PM
  4. First CNC build - VFD wiring question
    By Bez in forum Gantry/Router Machines & Building
    Last Post: 06-03-2015, 10:44 PM
  5. Limit switch wiring question ...
    Last Post: 31-10-2010, 11:06 AM
