Part of the problem and maybe the solution lies in your motion control software. There is usually a "CV" (constant velocity) setting. If this is turned off, the machine will stop at every change of direction and then restart. With it on, the machine tries to keep up a steady cutting speed by very slightly (and generally imperceptibly) rounding off the "corners" but giving a much smoother motion. Much smoother! Anyone who has been through this will know what I mean! This explains why straight cutting is fine but highly-faceted cuts are not.
This also helps the quality of finish doing the kinds of thing you are doing. I've just finished a project which involved copying a 3D relief carving by measuring the original across a 1mm grid and converting the mesh into a highly-faceted model and hence toolpath. However, using the appropriate CV setting I have a very smooth finished result. I also used vCarve for generating the toolpath although my mesh model came from other software. However, I would expect F360 or any other CAM software to do the same thing - it's generating a toolpath to match the model and the answer is at the motion control level.
Good luck!
Xyz malfunction very slow movement
By T3pbd in forum General ElectronicsReplies: 6Last Post: 19-09-2020, 11:37 AM -
Inverter and 3Ph Motor - Very slow revs
By CaptainBarnacles in forum Motor Drivers & ControllersReplies: 7Last Post: 07-03-2020, 01:28 PM -
Machine Slow on Curves
By swisscheese in forum Computer SoftwareReplies: 31Last Post: 12-04-2014, 12:49 AM -
Forum Slow
By pcstru in forum General DiscussionReplies: 3Last Post: 27-01-2011, 03:54 PM -
stepper speed very slow
By jonm in forum Stepper & Servo MotorsReplies: 17Last Post: 02-11-2009, 12:39 AM
