22-02-2021 #18
It might be possible to prevent this problem by fitting a resistor somewhere on the BOB to pull the relay control line to ground but without a circuit diagram it would be difficult to work out where it should go. Under normal working conditions you don't expect the PC to shut down suddenly but a safety interlock for tool changing is definately a good idea. I'm sure there is a discussion about this on the forum from a year or two back.
Problem using cnc3018 with offline controller
By gikkalan in forum Chinese MachinesReplies: 4Last Post: 11-07-2021, 05:33 AM -
Very Sick Lenze 534 Controller
By Ricardoco in forum Motor Drivers & ControllersReplies: 32Last Post: 09-09-2020, 11:19 PM -
Boxford 260VMC with toolchanger Lenze spindle speed issue/query
By swood1 in forum Boxford Vertical MillsReplies: 0Last Post: 27-03-2018, 03:18 PM -
tb6560 controller problem
By Wayne B in forum Linear & Rotary MotionReplies: 3Last Post: 22-01-2018, 10:58 PM
