Thread: CNC router for wood processing
15-02-2021 #2
I'm no expert, but seems like you have grasped the basics of the challenge and are grappling with the details.
Two minor points:
- Wood machines need speed, and so more normally use 1610 ballscrews. You can do the maths, but might want to gear up between stepper and ballscrew.
- As linear rails carry two spaced carriages wider than your ballscrew, typically ballscrews can be shorter than their rails.
A major contributor here always stresses ' buy nothing till you have finalized your design' but guess you have those parts already.
As to rail leveling, you are quite correct to focus on this as a key step to building an accurate machine. You will find plenty on this forum about epoxy leveling. If done right, it addresses both leveling the surface for the rails and getting them coplanar. Your adjustable screw approach is an alternative for leveling each rail, but seems a lot of work verses simply shimming the rail.
Good luck with your planningLast edited by Andrewg; 15-02-2021 at 01:01 PM.
My new 4 axes wood processing CNC router...
By florins in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 07-12-2021, 10:42 PM -
Wood cnc router for hobbyist
By nerostjames in forum Machine DiscussionReplies: 9Last Post: 01-01-2018, 09:28 PM -
SWAP: CNC Wood Router
By petesurrey in forum Items For SwapReplies: 1Last Post: 29-12-2017, 07:44 PM -
wood sign cut with cnc router
By jonm in forum Woodworking Project ShowcaseReplies: 5Last Post: 09-06-2014, 08:05 PM -
BUILD LOG: Wood Router
By Buba b in forum DIY Router Build LogsReplies: 18Last Post: 03-10-2012, 09:49 AM
