Ditto - although the transformer did go pop one day! But that seems to have been some random internal short as before that time it never even got warm. Those current figures are, to be honest, a bit vague. They don't really correspond with anything very much and in practice the load the drivers and motors put on the power supply is much less than your sums suggest. Hence my comments about motor temperature - for most practical purposes it's as good a guide as any! If you can hold the motor in your hand without it being too hot, then it's no more than 60C and that's fine for a stepper. It's what they do!
Your current/voltage sums are correct - power = volts x amps - but in this case, because the loads are pulses, of varying levels, and don't happen at the same time on all motors, then the average is lower than the sums suggest. In addition, using a linear PSU is a great idea as it is able to cope with short duration peak pulse overloads with ease, as long as the average load stays within spec. Translation - you can safely get away with it! Switch-mode supplies are cheaper, smaller, and lighter but do not like even very short duration overloads and go rapidly into sulk mode.
In your wiring diagram, connect A to C, -A to -C (can't replicate the exact terms in your diagram but I'm sure you can see what I mean), and then A/C to A+ on the driver, -A/-C to A- on the driver. Ditto for B&D. I think you know that you only then need four wires back to the driver.
I did have a strip of draught excluder brush with long bristles for my dust shoe but it was a pain to make - getting the groove right was tricky with the balance between too tight/too loose and bending the strip to fit was just a bit fiddly. My cheap and cheerful solution works at least as well and costs nowt into the bargain! That's an engineering solution...
14-02-2021 #2An optimist says the glass is half full, a pessimist says the glass is half empty, an engineer says you're using the wrong sized glass.
14-02-2021 #3
Absolutely correct - that was a weird way to label the connections! "Start of coil" ends of windings (marked with star) should go together. I confess that I was looking at the lettering and not the "star" marks - and the lettering does not seem to follow a logical convention. Nothing would have blown up my way - but nothing would have gone round either...
Well spotted!
15-02-2021 #4
Thanks for the replies gentlemen,
OK so I've been popping on most of the day for short burst to see what's been said but was unable to reply as I hate using my phone to do any forum posts. I've got back to my laptop to read your replies properly without the mither of a sugar loaded 4 year old.
I ran the program twice more this evening with the dust boot on and got the same results in both Trespa (HPL) and MDF. I nipped up the grub screws on the carriages to see if they were causing any issues ran the programs and had exactly the same deviation in the tool path at the same 2 locations. I'm concluding that there are two issues at play here. One I expected the other I didn't. Firstly it's definitely losing steps in both the x and y, the x was out by 0.23mm and the y was out by 0.18mm, I'm now going to change the wiring to parallel. I'll include the wiring diagram that I translated into english, if someone could confirm I got this right I'll try to get start on doing that tomorrow.
The second issue which is a bigger worry is the flexing on the Z axis. Those bristles are 0.6mm diam. the layer of bristles is about 6-7mm thick and when pressing down and sideways when it's machining it's flexing the Z axis at certain points because of the geometry of the part it was cutting. Bristles are easy to bend if the layer is only 2-3mm thick but 2 rows of a 6-7mm channel was enough to cause the z axis to bend enough to show up in the finished part. The bristles are already 15-20mm past the bottom of the cutter and when it's cutting 20mm deep they are forcing the z axis in 3 different directions, plus sometimes they go into the slot and get caught by the cutter. I'm opting for a single 0.6mm layer of skirt printed out in a strip to be fastened on to the rim. This should eliminate the forces acting on the z axis and contain the dust/chip spray when cutting. It's also much easier to make as it's 3 layers of PLA printed rather than cutting bristles off an old draft excluder and glueing them in vertically. We'll see how that goes. I'll include the sketch of what I mean below.
I didn't know it until tonight but I zero'd the tool to the work piece on both the x and y sides and pushed the neck of the spindle and on the side of the spindle to see what was going on. When I could see light passing between the workpiece and the tool I knew what was up. It was evident in both the x and the y but more so the y. This was disappointing but at least I know what was causing the movement. I'll measure the flex tomorrow/today but I'd estimate it's about 0.3mm in the Y and a little less in X. I should say that this machine is built from 20mm thick Trespa TopLab and uses supported 20mm rails. I was never meant to be a brute of a machine and was only for light materials such as MDF, foam, balsa and any other material used in pattern making. It is pretty tough though it cuts ali pretty nicely but you can't go too deep with it. The gantry design does allow me to lower it for more rigidity but I'm unsure if the flexing is the gantry upright plates or the combination of the Y carriage plate and Z axis assembly. For now I'll be using it for light machining and drilling ops for the MK2 version which will be a totally different design, mainly ali frame and components.
Without the dust boot it does cut MDF, Trespa and Ali to within 0.02mm to 0.04mm so I'm happy about the fact I can make the parts for the next machine on it. Hopefully with the wires in parallel and the printed skirt it should do what it needs to do without any more cock ups.
My bristles came from a draft excluder but your milk bottle idea made me think of the printed skirt idea, it's hands off and much less tedious to do. As for the wiring I think Kitwn confirmed what I thought when I read that so below is the schematic I'll follow when I rewire my motors...
The printed skirt...
The wiring schematic...
That's good news as I'm now reassured that there's enough power there.
I did the tuning but wasn't too sure what I was doing or what the Kp and Ki settings were about but found a decent guide in a Leadshine ProTuner manual, out of curiosity I'll try it again before I go parallel. They do squeal a bit which is noticeable when the ENA is not active (as in powered down) but I'll try them again when I'm back on the machine.
These motors are NEMA 23, I got them from Zapp a few years back but either they've discontinued them or for some reason, I may be wrong they seem to be listed as NEMA 24. Either way the frame size is defo 23. I might have used the wrong diagram but I wasn't brave enough at the time of buying to get the 34s. I bought all the electronics before I'd designed the machine. I was 10 years younger back then and didn't know exactly what I was doing or getting into.
As for speeds I think they stalled when rapiding at 7500mm/min so I brought it back down to 6000mm/min which is pretty quick over the size of bed I'm on, it's 915 in x and 515 in Y so not that far to go but I cut MDF at 4-5000mm/min, Trespa at 3000mm/min but shallow cuts only. I knew when buying the ballscrews that I should go with 10mm pitch but corona had started to go mental this time last year and the ballscrews were a bit of a panic purchase. The next machine is having 10's where needed and changeable pulleys for high res work.
As for the setting per phase or for motor total your last comment has really settled my mind. It's been bugging me for a while now with regards to what it meant. Not just on the router but on any stepper system. Anyway I can rest my mind on that one.
OK I'll see what happens with the new skirt tomorrow or Tuesday. Rewiring motor plugs, checking all the fasteners and re-tuning should see me good for a couple of days, I'll then report back.
Thanks again for your responses, I'd be goosed without this forum.
15-02-2021 #5
15-02-2021 #6I would change the motor wiring one motor at a time (obviously the twin screws will have to be done together )OK I'll see what happens with the new skirt tomorrow or Tuesday. Rewiring motor plugs, checking all the fasteners and re-tuning should see me good for a couple of days, I'll then report back...Clive
AM882 software ProTuner & windows 8.1
By paulus.v in forum Computer SoftwareReplies: 11Last Post: 22-09-2017, 02:50 PM -
Stepper motor / driver mismatch?
By lockyg in forum Motor Drivers & ControllersReplies: 9Last Post: 10-02-2016, 09:30 AM -
How do I wire a stepper driver to a stepper motor?
By swood1 in forum Stepper & Servo MotorsReplies: 7Last Post: 21-09-2014, 05:40 PM -
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
Stepper Motor Driver v2.3 2A $20 !!!
By Lee Roberts in forum Motor Drivers & ControllersReplies: 15Last Post: 17-05-2009, 10:57 PM
