The only reason to use a brake is to hold the position when the motor is De-powered. ie: Z axis. Other than that there is no value in using one on the other axis IMO because unless you are using an absolute servo system which knows the servo's location after de-powering or hitting E-stop or faults you will alway need to reference the axis to Zero (home)
The Mechanical brakes fitted to motors are not designed to brake the motor from speed and only used to hold the motor when at stand still, most servo's won't allow you to apply the brake if the rotor is still turning.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
NEW MEMBER: New Member - with first question on Hardinge spindle brake spring
By EHirst in forum New Member IntroductionsReplies: 1Last Post: 16-09-2020, 07:51 AM -
4th axis brake enquiry
By marbles in forum Linear & Rotary MotionReplies: 17Last Post: 12-05-2020, 09:02 AM -
DIY 4th Axis with Brake - The Build
By koenigsegg in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 03-02-2020, 07:39 PM -
lathe dc servo motor brake/spindle lock ??
By dazza in forum Lathes, Lathe Rebuilding & ConversionsReplies: 0Last Post: 01-11-2014, 05:22 PM -
Drill/Mill Spindle brake (RF30)
By BillTodd in forum Machine DiscussionReplies: 12Last Post: 04-11-2009, 12:09 AM
