Thread: servo and spindle advice please
hi i need some advice please
i am converting my denford cyclone lathe.
it now runs using centroid acorn with cnc12 lathe .
i am thinking of losing the stepper motors (8nm nema34) and using ac servo's with they're encoders.
i have never done anything with servos before ,but i want the accuracy and don't want to lose steps like i occasionally do with the steppers.
ive seen servos with drivers around £300 can anyone recommend some that will do the job and they're power please plus someone reputable to buy from.
Also the spindle motor is a 4 pole 2.2kw 1:1 with the spindle via a belt.
currently it is controlled by a cheap 4 kw hy vfd ,0-76 hz gives me 2200 rpm ,the motor has stalled in the past and not a lot of torque at lower rpm
i would like to ridged tap in the future .
so would a better vfd with senseless vector (yaskawa v1000) give me more power and enable ridged tapping ?
Ive heard of servo motors being used for spindle drives would this work in my application if so recommendations on power and a seller
cheers
Servo as a spindle motor replacement - what to look out for?
By Doddy in forum Stepper & Servo MotorsReplies: 23Last Post: 05-10-2020, 10:34 PM -
Adding a 4th axis spindle to my mill, servo troubles
By Davek0974 in forum Milling Machines, Builds & ConversionsReplies: 18Last Post: 28-05-2019, 06:28 PM -
lathe dc servo motor brake/spindle lock ??
By dazza in forum Lathes, Lathe Rebuilding & ConversionsReplies: 0Last Post: 01-11-2014, 05:22 PM -
2.2kw servo motor for spindle
By blayde in forum Spindles & Drive MotorsReplies: 1Last Post: 01-01-2014, 04:48 AM -
servo as a spindle
By Swarfing in forum Stepper & Servo MotorsReplies: 2Last Post: 27-10-2010, 12:30 AM
