Thread: Xsy-at1 connection translation
Hi All
Please excuse my lack of knowledge.
Can anyone help me? I am trying to connect my XSY-AT1 to a Gecko G540 using a relay to control the motor with MACH3.
My problem is trying to work out the correct connections on the VFD.
See attached photo. I wish to connect the outputs from the relay to For and DCM which are not labelled on the XSY-AT1. It looks like I should use X4, can someone verify if I have this correct.
Thanks in advance.
GregLast edited by GREG021; 16-02-2021 at 06:53 PM. Reason: Forgot photo
16-02-2021 #2
Current Activity: Viewing Cheap milling machine spindle - BT30-ER20, air powered draw bar + Tear Down!
Hi Greg
In my video series here I talk about wiring this exact inverter up for external control. See episode 2 & 3. You will have to fast forward through some other bits to get to the section that might help you.
https://www.youtube.com/watch?v=NiXF...RN7i6ecMuwH6RRLast edited by routercnc; 17-02-2021 at 07:17 AM.
17-02-2021 #3
Hello
Thank you for your reply.
What a great job you have made, you have paid a lot of attention to detail, design and build quality.
You have confirmed that x4 is forward and x5 is reverse.
I wanted to be sure.
I am going to be using a Gecko G540 the XSY-AT1 and MACH3to control a Denford Easimill.
Looking forward to being able to machine my own parts when I need them.
I have a TVR Griff which needs some decent parts instead of the TVR quality ones.
I will let you know if all goes well.
In the meantime.
Kind Regards.
Greg
17-02-2021 #4
OK no problem. Good luck with the TVR. My friend had one years ago and it was a great car but developed issues so he sold it.
17-02-2021 #5
Thank you.
Regarding TVR's you do have to love to own them.
Again many thanks.
Greg
Which Connection ?
By manofgresley in forum Stepper & Servo MotorsReplies: 17Last Post: 13-07-2020, 01:55 PM -
Connection hub
By Agathon in forum General ElectronicsReplies: 9Last Post: 18-05-2020, 09:06 PM -
6040Z USB connection issues
By rogw in forum Chinese MachinesReplies: 8Last Post: 01-08-2019, 08:30 PM -
Or Guidance ;) Connection Name(s)
By Carlb1058 in forum Marketplace DiscussionReplies: 6Last Post: 13-07-2013, 12:48 AM -
Wire Connection Diagrams
By Lee Roberts in forum Stepper & Servo MotorsReplies: 14Last Post: 03-01-2013, 06:56 PM
