Thread: Inkscape? jscut problem
18-02-2021 #1
Hopefully someone can help, I drawn some lines within a desigb I am doing with inkscape using the straight line tool, I increased the size to 1,5mm I have tried everything using the fill and stroke tools, then grouped the lines together, then object to pass. saved it, but when in JS cut I am unable to select them.
I went back to the inkscape design tried using most of the PATH menu's but still unable to select them in JScut. a;; the rest of the design selects ok, I even increased the lines to 4mm in case I was not getting the curser on them, but still no joy.
I have been routing the lines manually but that is a pain.
Hoping someone can help solve this for me
21-02-2021 #2
First, thanks for getting me to look at my installation of Inkscape, which I transferred from my old Windows User to a new one (which I had to create to overcome problems of Microsoft's creation). I realised that the installed extensions had not been transferred. So that is another task for me !! I loathe Microsoft !
My first thoughts on your problem.
a. Somehow the lines that you think are vectors are bitmaps.
b. Your lines that are missing are on a different layer.
If you can let me have your Inkscape files, I will be able to look in more detail.
Cheers,
Rob
22-02-2021 #3
cant seem to work out how to send the file privately
22-02-2021 #4
https://www.dropbox.com/request/EnqH7fAh3CIpkLa4d6Z7 Put your file in this folder
22-02-2021 #5
The BSA logo is cut on JScut as an inside cut, the 4 lines are a pocket cut, so can not be combined with the logo, also the lines look ok until you enlarge the image
OK, I think I have a grasp on the problem. The 4 lines in the wing are just that - lines - and making them thicker lines in Inkscape only means that they convert to a line vector for JSCUT. Try drawing them as rectangles.
Cheers,
Rob
22-02-2021 #7
thanks sorted
Inkscape problem
By RichardR in forum General ComputingReplies: 5Last Post: 06-01-2021, 11:00 PM -
Inkscape boxmaker
By cropwell in forum Computer SoftwareReplies: 1Last Post: 30-01-2018, 10:07 AM -
Inkscape
By Janste in forum CAD & CAM SoftwareReplies: 3Last Post: 13-01-2015, 04:20 PM -
DXF into inkscape problem (SVGexport)
By GEOFFREY in forum Computer SoftwareReplies: 10Last Post: 09-03-2013, 07:52 PM -
Free CAM for Inkscape
By Zar in forum General ComputingReplies: 4Last Post: 24-08-2010, 02:37 PM
