    thanks
    is there any disadvantage to 750w or 1kw on both, as for gearing was it 1:1
    please correct me if im wrong but im under the illusion that with the servos and driver kit if it "loses steps" ie out of position it will alarm or something to stop inaccurate turning
    Lives in East Lothian, United Kingdom. Last Activity: 12 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,970. Received thanks 369 times, giving thanks to others 9 times.
    Quote Originally Posted by iamspuddy View Post
    thanks
    How much breaks if something goes wrong :-)
    Although too big a servo on too light an axis can cause tuning/stability problems.
    IIRC the amount of space available to put a bigger motor on the X-axis is limited, so it's something you have to consider.
    I think I went to somewhere around 2:1 ratio, possibly a bit higher.
    Steppers aren't fast, and it's unlikely you'd ever run one above 1000rpm (500rpm is probably more feasible for reliable operation), whereas most servos around a similar size will quite happily spin at 3000rpm.
    If you direct couple a servo at 5mm pitch, at full speed you'll theoretically get 15m/min, but you're never likely to reach that speed due to the axes being so short, there simply won't be enough distance to accelerate/decelerate to that speed. So it's far better to gear to get better acceleration, and make better use of the servos potential rather than limit how fast it spins.
    It all depends on how you program them, but they should do. There will be a following error parameter, that can trigger a fault when a set number of counts out of position is exceeded.
  1. servo and spindle advice please
    By iamspuddy in forum Stepper & Servo Motors
    Last Post: 15-02-2021, 08:10 PM
  2. Beam choice
    By idegraaf in forum Gantry/Router Machines & Building
    Last Post: 22-03-2018, 07:38 PM
  3. VFD choice
    By D-man in forum Spindles & Drive Motors
    Last Post: 20-02-2016, 03:38 PM
  4. CNC router choice out there.
    By CTJ in forum Machine Discussion
    Last Post: 10-12-2015, 09:51 PM
  5. eBay: SEM SERVO MOTOR SEM MT30 U4-48, LAMBDA psu,s, 160v servo drive
    By dazza in forum Items On eBay UK
    Last Post: 29-01-2015, 08:55 AM
