I was thinking in terms of a series of 2D cuts rather than a true spiral. The maths would be a lot simpler, though I can see the desire for the best surface finish straight off the machine when you're cutting stainless. Not quite as easy to sand afterwards as hardwood!
KitAn optimist says the glass is half full, a pessimist says the glass is half empty, an engineer says you're using the wrong sized glass.
Vector Aspire problem - drill toolpath converted to pocket toolpath
By pablocordal in forum CAD & CAM SoftwareReplies: 5Last Post: 31-10-2018, 02:26 PM -
Need advise on aluminium cone/horn design, ideally from a lathe machinist.
By JOGARA in forum General DiscussionReplies: 5Last Post: 12-05-2018, 02:05 AM -
Feeds and speeds settings for compression spiral
By Metal pecker in forum General DiscussionReplies: 2Last Post: 02-07-2016, 06:41 PM -
Long Down Cut Spiral End Mills
By Bazzer in forum Marketplace DiscussionReplies: 2Last Post: 23-12-2013, 06:11 PM -
Wealden Tools enlarge range of spiral router cutters
By Routers in forum Manufacturer NewsReplies: 0Last Post: 01-07-2011, 12:42 PM
