    Hello everyone,
    Could I ask for recommendations for a powerful - and if possible not to noisy - vacuum cleaner to use with a cyclone and a dust bucket?
    I will also want to connect it to a dust shoe when i get round to making one.
    Our old Dyson Animal has lost some of it's suck!
    Thanks...Chris
    In spite of the hype, Dyson's do actually have filters in them which need to be cleaned regularly for maximum suck. There might be life in the old beast yet!
    Kit
  3. The Following User Says Thank You to Kitwn For This Useful Post:
    Lives in East Lothian, United Kingdom. Last Activity: 17 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    If it's a Dyson, strip the cyclone section down and give it all a wash. IIRC there's a ring of screws that hold it all together.
    They eventually clog up, especially if they've been used for anything damp/sticky, which wood dust can be.
    And give the filters a wash out at the same time.
  5. The Following User Says Thank You to m_c For This Useful Post:
  6. #4
    I've been using one of these for a few years now. Stands a lot of abuse, and at that price when it does eventually blow up, I'll just bin it and get another one. I seem to remember getting the optional filter for it - like a car air cleaner filter element. It just gets cleaned from time to time - can't remember now why the original element isn't as good, it's so long since I got it! But it's not quiet. Not horrendous but I wear ear defenders more for the vacuum cleaner than the CNC router...
    BTW, watching your video - I wouldn't bother slowing the ramp speed with cuts like that. Just ramp in at the usual cutting speed. Probably could take a bit more depth of cut as well as more cutting speed, but if you're still feeling your way with the machine, I can understand a bit of caution! And it throws the dust and chips even further...
  7. The Following User Says Thank You to Neale For This Useful Post:
  8. #5
    Thanks Neale, i'm definitely still feeling my way with the machine and software etc for that matter. Didn't alter much g code wise from what fusion 360 CAM spat out. Other than adding G91.1 and G54 commands because it just wouldn't work from the original post process. I certainly need to learn more about feeds and speeds to improve on efficiency. Each one of these cuts took 8 minutes but it felt much longer chasing the cutter around with an old dyson. I need to get a little more organised!
  9. #6
    I have been using the Wickes vac for a while now (about 7 years) and waiting for the noisy bugger to blow up, but it seems pretty good still. I have a cyclone and bucket (actually a large glass jar) and I recently replaced it with a transparent lidded bucket, but that spectacularly imploded the first time I tried it when I blocked the inlet with my hand.
    I have a small drum filter from an ash bucket on the top of the cyclone, in a 3d printed enclosure. This stops anything the cyclone doesn't and when the vac stops anything in it drops down through the cyclone into the collection bin. This keeps the main vac filter clean enough to consider not having it. So that might be put on the project list (to cut down the vac to a basic air mover to save space).
  10. The Following User Says Thank You to cropwell For This Useful Post:
  11. #7
    Big fan of Nilfisk myself, concocted this from bits bought from fleabay, the cyclone is mounted in the middle section. The nilfisk motors are continuously rated, not too noisy and will run 10hrs non stop, not many domestic vacs will do that.
Name:	Dust extractor.jpg
  12. The Following User Says Thank You to johnsattuk For This Useful Post:
  13. #8
    Quote Originally Posted by johnsattuk View Post
    Looks like something the Russians would have sent into space around 1958
    Kit
  14. The Following User Says Thank You to Kitwn For This Useful Post:
  15. #9
    These look like good machines!
  16. #10
    I’ve been using a Henry for years. Quiet, cheap (£120), good suction, simple to clean out. I had intended to build or buy a cyclone or just simple in - out intermediate bucket but never got around to it. Just the Henry works great.
  17. The Following User Says Thank You to routercnc For This Useful Post:
  1. Dust extractor noise!
    By andy_con in forum Dust Extraction & Collection
    Last Post: 23-09-2020, 09:37 PM
  2. Which vacuum cleaner (Karcher MV2?)
    By d4cnc in forum Dust Extraction & Collection
    Last Post: 31-10-2018, 08:16 AM
  3. Recommend a small Vacuum for use with Dust Commander Vortex?
    By Millatime16 in forum Workshop & Equipment
    Last Post: 13-04-2018, 01:51 AM
  4. Building a cnc dust boot / dust skirt extractor
    By craynerd in forum Workshop & Equipment
    Last Post: 13-03-2016, 01:50 PM
  5. Cyclone Chip/Dust Extractor for under £20!
    By KevinC in forum Dust Extraction & Collection
    Last Post: 10-10-2015, 10:51 AM
