Thread: TT wall art
    I got chatting to a workmate who wanted a IOM TT track on his wall. I wanted to have a go at epoxy resin in wood after seeing Wal's work so I offered to give it a go. I have a few issues to fix if I want to start to sell items like this but I'm pretty pleased with the first attempt.
    First issue is the panel has bowed so I think I'll have to rough out the shape, skim the back flat and then finish the front. Secondly, the resin seemed to take way longer to cure than the recommended 12-24hrs...I'm not sure if this is because of the pigment, Temperature or just the resin....I need to experiment a little more I think.
    The resin also chipped slightly so I think I will machine the swirl in two passes next time. Any recommendations on what to use to polish up the resin?
ID:	29630Click image for larger version.
    Andrewg's Avatar
    Lives in Cambridge, United Kingdom. Last Activity: 23 Hours Ago Has been a member for 5-6 years. Has a total post count of 74. Received thanks 13 times, giving thanks to others 34 times.
    Looks very classy.
    Re. Wood bowing, how deep do you make the carving?
    And what resin and dye did you use? Did you have any issue with bubbles?
    Did you leave it sitting flat overnight?
    Better to position for even airflow (upright with both faces exposed)
    Quote Originally Posted by pippin88 View Post
    It was left clamped for a few days but there was plenty of airflow below the workpiece....I'm not sure if you could tell from the image but I had it screwed through the back supported on the top and bottom edge only, I removed 9mm leaving 10mm panel thickness at the deepest points. It bowed by approximately 0.5mm on each end, probably just the wood relaxing so now I'm aware I will change methods slightly. My workmate is happy enough though :)
  5. The Following User Says Thank You to CharlieRam For This Useful Post:
  6. #5
    Wal's Avatar
    Looks great..!
    Wal.
  7. The Following User Says Thank You to Wal For This Useful Post:
  1. BUILD LOG: 8x4 Wall Mounted; Upright ply cutter
    By kingcreaky in forum DIY Router Build Logs
    Last Post: 26-01-2015, 06:33 PM
  2. WANTED: 150mm dia x 15mm wall Ali pipe
    By r0bsk1 in forum Items Wanted
    Last Post: 12-06-2014, 04:19 PM
  3. wall cnc like the wall saw
    By crossleymarko in forum Machine Discussion
    Last Post: 25-03-2012, 11:24 AM
  4. wall and floor fixing am I the only one ????????????
    By luke11cnc in forum General Discussion
    Last Post: 30-12-2011, 11:45 PM
  5. CNC Wall art from JPG
    By BJ- in forum Opportunities Available & Sought
    Last Post: 29-01-2010, 03:06 PM
