Thread: TT wall art
  1. #4
    Quote Originally Posted by pippin88 View Post
    Did you leave it sitting flat overnight?
    Better to position for even airflow (upright with both faces exposed)
    It was left clamped for a few days but there was plenty of airflow below the workpiece....I'm not sure if you could tell from the image but I had it screwed through the back supported on the top and bottom edge only, I removed 9mm leaving 10mm panel thickness at the deepest points. It bowed by approximately 0.5mm on each end, probably just the wood relaxing so now I'm aware I will change methods slightly. My workmate is happy enough though :)
  2. The Following User Says Thank You to CharlieRam For This Useful Post:
  1. BUILD LOG: 8x4 Wall Mounted; Upright ply cutter
    By kingcreaky in forum DIY Router Build Logs
    Last Post: 26-01-2015, 06:33 PM
  2. WANTED: 150mm dia x 15mm wall Ali pipe
    By r0bsk1 in forum Items Wanted
    Last Post: 12-06-2014, 04:19 PM
  3. wall cnc like the wall saw
    By crossleymarko in forum Machine Discussion
    Last Post: 25-03-2012, 11:24 AM
  4. wall and floor fixing am I the only one ????????????
    By luke11cnc in forum General Discussion
    Last Post: 30-12-2011, 11:45 PM
  5. CNC Wall art from JPG
    By BJ- in forum Opportunities Available & Sought
    Last Post: 29-01-2010, 03:06 PM
