Thread: Z Axis Design Help
Thanks for the reply Kitwin,
I have Bandsaw, Pillar Drill, Heavy Duty hand held Router, small selection of taps/dies and the usual home mechanic/wood worker range of tools (heavy & light duty) and not afraid to try something I haven't done before (hence here
I had read that larger than 15mm rails are better, but is it better to use larger bearings as well ?
I'm trying at this stage to get to grips with what is better for strength/rigidity and direct my design/expenditure towards the most influential areas.
Roger
02-03-2021 #2
You're over the biggest hurdle then. I think one of the main obstacles for many people is getting started and being willing to have a go at something new (I should have bought a welder about 2 years before I finally plucked up the courage to have a go). Though you are right to start by asking questions rather than just buying bits off eBay and hoping for the best.
And the other biggest hurdle is aquiring all this knowledge before comitting your limited budget in the most cost-effective way. I can't answer this particular question from personal exprience but you will see designs where people have had to cut channels for the ballscrew to fit into which isn't ideal, especially if you don't already have a milling machine to hand. The narrower you can make the Z assembly, the more cutting length you will get from a given set of rails and ballscrews on the Y (X) axis so your choice of bearings should take this into acount.
It's also worth checking the materials you have available locally. Not too much of a problem when you live on such a tiny, crowded island, but if you can design around what you can get hold of nearby it helps.
KitLast edited by Kitwn; 02-03-2021 at 01:48 AM.
Z AXIS Adjustment design Help
By RobC in forum General DiscussionReplies: 0Last Post: 11-04-2019, 04:50 PM -
Z axis design
By tzar in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 16-12-2014, 09:48 PM -
Z-Axis design and advice
By Mad Professor in forum Gantry/Router Machines & BuildingReplies: 22Last Post: 06-04-2013, 11:00 AM -
Need 6' x 4' bed, 4 axis router design.. Help..!
By fasteddy in forum Gantry/Router Machines & BuildingReplies: 29Last Post: 17-09-2010, 12:56 PM -
Y axis design
By GeorgeD in forum Gantry/Router Machines & BuildingReplies: 9Last Post: 15-07-2010, 03:04 AM
