Thread: Driver help
Thats exactly what I have now. Seems to be ok except I think the y axis has blown. Im going to try using the b axis output this afternoon, and If that works ill buy another couple
06-03-2021 #2
It's certainly possible to blow a single output - though a little unusual. Definitely worth substituting B - yup. If you still have a problem then think of the signal chain (for example, you could use another channel on the UC300 - just remember not all are the same, but there's at least 2 with the 11-outputs/5 input configuration.
06-03-2021 #3
Yep I tried changing from port 2 to 3 but no difference
06-03-2021 #4
I've just read the thread through - yeah, try changing the outputs still, but keep in mind the stepper drivers. In a pinch, I'd try disconnecting the step/pulse input to the driver and just flashing 5v across it (make/break with a bit of stripped wire) - all correct polarity of course. Quick way to check that the driver hasn't been borked along the way. Zero-cost, removes a component from the diagnostics.
06-03-2021 #5
I used z wiring on the y driver and it works so definately the bob
06-03-2021 #6
Well I've sorted the issue. Turns out the new cat 5 cable i used to wire the drivers had a break it it somewhere. Used a new bit of cable and success. Doddy, do you use the screw terminals or do you have connectors to plug in to the board?
06-03-2021 #7
That rings a bell, I'm sure someone else had a similar problem a while back. Was it monofilament cable?
I've got one of these which turns a laptop into a two channel oscilloscope and has proved invaluable for tracing pulsed signals and would have found your broken wire very quickly. No doubt there are those who will say it's too complex a bit of gear for some people to use but in trying to fault-find on a CNC router you are already dealing with a complex bit of gear and need the right tools to show you what's going on. It's part of my standard electronics tool kit along with my multimeter and soldering iron. Is it expensive? Depends on how much money you would have wasted on replacing BOBs, drivers and other components that were never faulty.
Kit
https://au.element14.com/pico-techno...g/dp/236542501An optimist says the glass is half full, a pessimist says the glass is half empty, an engineer says you're using the wrong sized glass.
07-03-2021 #8
I agree 100% with the sentiment of your post, but you hit the nail on the head here. Not that, as a tool, it's complex - yes they can be (and heaven forbid you ever try a LeCroy which - despite warnings - I bought one through the company and hit myself every sodding day for the reversed timebase/Y-deflection controls (everyone warns you about it - but you think you'll get used... you don't!) The problem is that a lot of people know what signalling is expected, and a scope would work for them - but even without a scope knowing what to expect allows a whole load of diagnostics with nothing more than a meter, LEDs, bits of wire and a cup of coffee with a hobnob.
For those that don't understand the signalling, a scope would just be a gateway to the unknown.
Perhaps we need a sticky for the typical signalling across a CNC system and easy approaches to test each node. But that assumes a convention to the controller design. There's no easy win to this.
It's frustrating as hell to try to help someone a couple of hundred miles away over a few days or weeks when you realise that in the long run it'd be quicker to just jump in the car and fix the problem yourself. No disrespect to anyone intended - we all have our own areas of interest/experience.
07-03-2021 #9
And I agree 100% with yours! Everything is easy when you know how, that's why we employ specialists to perform specific tasks. I wouldn't trust a brain surgeon to service my car or a car mechanic to sort my head out. Actually I don't think there's anyone clever enough to do that, but I digress. One of the key elements of a hobby like ours is attempting to become an expert in several different and complicated disciplines in next to no time and with no formal training.
Knowing how to trace faults in electronic equipment is a skill in itself. I have followed some of your past efforts to help others at a distance and am genuinely impressed at your patience and perserverance in the face of dificulties. I do like the idea of a sticky thread covering some of these issues. What the various signals consist of, how you can trace them through the equipment with simple, inexpensive test gear and what you can and cannot properly measure with an ordinary digital mulitimeter (the one you simply cannot do without if you expect to build you own machine) would be very useful to many.
Kit
P.S. We spent today at Steamfest in Sheffield. One of the junk stalls (sorry, "vintage tools emporium" ) had a lovely old bakelite AVO meter for $80. I was very tempted. It was the same as the very first piece of test equipment the BBC trained me to use when I was a lad.Last edited by Kitwn; 07-03-2021 at 05:20 AM.
06-03-2021 #10
I tend to use the screw terminals (with ferrules), bit daft since I have the connectors (I think). But screw-terminals allow you to maintain things with a banana, at a push :)
Driver led's
By Duffman in forum Motor Drivers & ControllersReplies: 5Last Post: 16-01-2016, 02:41 PM -
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
Dc servo driver
By Treemonkey in forum Motor Drivers & ControllersReplies: 11Last Post: 11-02-2013, 08:16 PM -
Driver Lights Red
By Toddy in forum Motor Drivers & ControllersReplies: 6Last Post: 05-11-2011, 03:46 PM -
Driver box
By John S in forum General ElectronicsReplies: 1Last Post: 21-06-2009, 12:46 PM
