Thread: New Controller Needed
07-03-2021 #1
I've not been using my CNC Router much for some time so decided to give it to my nephew (he is over 20 and into woodworking so not a kid). When i took it over, the PC decided it had given up the ghost so i went back with a newer PC that i was using for my laser until recently. This PC is running on Win7 64 Bit so i tried everything until i found out 64 bit is the problem.
So, i'm deciding whether i can find an old PC that will work or change to a new controller box (which seems like the simplest option). Is there anywhere that will sell me a USB black controller box to run this off? I can find full CNC's on Ebay and Amazon but no Controller box options.
Thanks for any help
07-03-2021 #2
Just instal win7 32 bit. Must be the easiest solution
07-03-2021 #3
I have thought of that depronman, but i'm not 100% if the problem is only the Operating System or if there's an issue in the controller too so thought about trying a new controller.
08-03-2021 #4You think that's too expensive? You're not a Model Engineer are you? :D
08-03-2021 #5
When you say you want a new controller are you just meaning the motion control card side or the whole control box with drives and everything else.? there's a big difference.!
To help properly then more info about the machine and what you have already would be required, it's not something we can guess at.!-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
General advise needed on CNC Controller and Servo/stepper motor upgrade.
By Mister Mills in forum General DiscussionReplies: 11Last Post: 02-10-2020, 09:49 PM -
Help needed to connect my VFD to the AXBB controller
By CharlieRam in forum Spindles & Drive MotorsReplies: 24Last Post: 23-09-2020, 12:10 PM -
Usb controller
By pemmott in forum Artsoft Mach (3 & 4)Replies: 3Last Post: 02-12-2019, 07:34 PM -
Advice needed for controller box layout
By Bustercnc in forum General ElectronicsReplies: 23Last Post: 18-01-2016, 01:16 PM -
Help needed Dahlgren System 4824 And a DSC controller, what software will run it???
By fraserguitars in forum Machine DiscussionReplies: 0Last Post: 13-12-2015, 08:22 PM
