Delta do have torque graphs. They have a good manual which is partly why they are worth paying for.
You will get 100% torque to rated speed then it will drop off to max speed.
You then have continuous vs intermittent duty zone.
The servo will be happy all day in the continuous zone. The time in the intermittent zone depends on how much over the continuous zone you are. E.g. 110% will be ages where as 300% willintermittent
This info is also in the manual but slightly harder to find.
The Following User Says Thank You to pippin88 For This Useful Post:
07-03-2021 #2
Good to know they have manuals thank you.. i've searched on their web and not found anything as yet but ill take another look
Rated speed for cutting and then max speed for rapids made more sense in my head after i thought about it. However, i wonder if i should just keep it simple at 2krpm gear it down to a sensible speed (still more than i could ever really need) while giving me more torque than ill probably ever need and just be done with it.
08-03-2021 #3
08-03-2021 #4
Thinking in speed terms is the wrong approach because after your rolling it takes very little power to keep it rolling, slowing down, and changing direction is completely different and this is where rotor inertia, Mass, torque, etc come into play.
The fact you can travel at 50mtr.min might seem great until you come to stoping the bloody thing and it overshoots because the inertia of the moving mass and rotor together run out of brakes.
Likewise hitting the throttle hard is the same thing in reverse, so high rotor inertia, heavy mass requires lots of power to get things moving, after which hardly any is needed to keep it moving, then the cycle starts again to slow down/change direction.
It's these things, among others, which can make tuning the motors difficult, achieving high feeds is easy but not always a good thing.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
How to setup Chinese AASD Servo electronic gearing
By JAZZCNC in forum Machine DiscussionReplies: 12Last Post: 02-07-2022, 03:11 PM -
eBay: SEM SERVO MOTOR SEM MT30 U4-48, LAMBDA psu,s, 160v servo drive
By dazza in forum Items On eBay UKReplies: 0Last Post: 29-01-2015, 08:55 AM -
AC servo motor to replace a 3 phase induction motor on a mill spindle.
By rnr107 in forum Spindles & Drive MotorsReplies: 2Last Post: 23-04-2014, 03:14 PM -
M542 driver - motor vibration at low speeds
By birchy in forum Motor Drivers & ControllersReplies: 34Last Post: 22-11-2013, 08:16 PM -
motor gearing (cog) help please
By martin54 in forum Linear & Rotary MotionReplies: 5Last Post: 06-07-2013, 11:48 PM
