Thread: Refinishing options?
17-03-2021 #12
I'm leaning towards the single pack enamels like Tractol at the moment and may try roller first to see what the finish is like.
Because I haven't been able to get it blasted im a bit concerned about the rust. sanded and scotchbrited but obviously its still there in places. Is it worth spraying with cold galvanised first to seal or just use red lead or the products primer.?
You could use some rust converter.
I've used POR15 metal prep in the past, and if you can keep the rust wet for a few days with occasional agitation, it will dissolve all rust.
It'll even dissolve rust in pores that blasting can't get to.
Alternatively if you can find a suitable container, a few hours electrolysis will also dissolve rust.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
17-03-2021 #14
I have been looking at the POR 15 products and they have been recommended a few times.
I've seen a few machinery enamels that can be thinned by white spirit, and are much cheaper. Are these likely to be as hard wearing as the other enamels?
Also looking at PPG selemix 7-610, as I think I can get that locally, its a synthetic enamel so the thinner is pricey, but cant find out if it is oil resistant for the using flood coolant.
17-03-2021 #15
17-03-2021 #16
The 2 pack I've used is polyurethane - great stuff BUT YOU MUST WEAR APPROPRIATE PPE WHEN SPRAYING otherwise you will be really quite ill for a long time. I can't recall the manufacturer of it (was a few years ago), but seem to remember that it came from Germany. I've never used the epoxy myself, but a friend did and said it gave a very durable finish. Some quick googling turned up this stuff which seems pretty reasonable: https://www.taindustrialpaints.co.uk...pular-colours/
I've found drying at elevated temp. helps with pretty well all air dry paint types whether it's enamel out of a tin from the local paint dealer or even stuff in an aerosol: I don't think it's by chance that a lot of industrial finishes are referred to as "stoving enamel". Mind you the weather is generally cold and damp up here, not the best conditions for drying stuff.
Lathe ATC Options?
By Ross77 in forum Lathes, Lathe Rebuilding & ConversionsReplies: 35Last Post: 28-08-2020, 12:13 AM -
4th Axis options?
By Ross77 in forum General DiscussionReplies: 8Last Post: 13-01-2020, 04:31 PM -
Fed up with Mach3 - what options do i have here??
By Davek0974 in forum Bridgeport Milling MachinesReplies: 9Last Post: 22-04-2018, 06:49 PM -
PC Upgrade Options?
By Chaz in forum General DiscussionReplies: 11Last Post: 31-08-2016, 04:53 PM -
ATC Options?
By Davek0974 in forum Gantry/Router Machines & BuildingReplies: 25Last Post: 14-05-2016, 08:25 AM
