Doddy, good idea re the power supply. Doing that wouldn't create any risks of earthing loops would it? I only ask cos I had a nightmare when I first built this kit with steppers twiddling randomly while I watched. Turned out to be entirely due to my ignorance in that I thought I was doing a better job by earthing both ends of the shielding on the stepper cables
Edit: bugger. Power supply is 27V, just enough to exceed 24V max for UC400!
12-03-2021 #2
Well, that's not entirely true... The UC300 and 400 needs some sort of a BoB, because you need to split the contacts. Doing that without any BoB is possible, and as you said, most drivers have optical isolators anyway, for for that, you don't need a BoB but you definitely need some way of splitting the signals and lead them to the right contact on each driver. So "easy" is a very wide word. With a BoB it is easy, but without it is not so easy.
12-03-2021 #3
Ah, I think I see where our thoughts are not quite joined up - I'm talking (and I'm interpreting Ian's intent here) - of connecting the UCx00 to the 25 pin D-Sub connector on the control box, using the internal System 4C components that implement the BoB and the Driver electronics. NOT, taking the UCx00 device to connect direct to the drivers.
12-03-2021 #4
Doddy, you have interpreted my intent correctly
So connection wise I think I'd only need a D-sub 25 pin connector to solder on to one end of my lpt cable.
I'm hoping you were meaning the main board 12V (12-24) supply for the UCx00 when you mentioned 5V.
I had realised the 12V board supply isn't rated highly enough for the UCx00, which is a pity.
Back in 2012 I did post on here a few times while I was trying to sort out the earthing faults, but it looks like that is a time that has been lost to internet history!
A_camera, sorry I didn't explain things more clearly
. If I can manage it, I'll post the manual and assembly pdfs....
Here we go, at least they are on the site if anyone needs them..
Case Installation.pdfManual.pdf
Ian
12-03-2021 #5
Nah, you'll need a common ground in any case between the UCx00 and the interface so that's largely by-the-by. I'm surprised you had that problem - but electromagnetic is all black magic to me.
12-03-2021 #6
That control box (System 4C - I've found the PDF for it) - implements the functions of the BoB across 2-3 boards. It's fine. Just don't try to power the UCx00 5V supply from it (100mA max).
12-03-2021 #7
I see. Thanks for clearing the confusion. Yes, that's easy to do. You just plug in the UC400 to the DB25 on the box. No need of soldering because there is a ready made ribbon cable which is delivered with the UC400, which is the obvious choice for you. Just connect that to a small psu and to the LAN and off you go. It should work immediately once you have configured it. Will you be using UCCNC as well? I think it would be the best and maybe CNCDrive has some special deal when you buy both. I got my license almost for free when I bought my UC300ETH some years ago.
13-03-2021 #8
Well I've spent some money...
Dean only stocks the UC300ETH and AXBB so I've ordered a UC400ETH direct from CNCDrive.
We'll see how buying from Europe works these days...
I'm expecting to have to pay the VAT when it gets over here. I think I should save about £25 compared to buying from CNC4YOU.
I didn't order the UCCNC software cos I was chugging along OK with Mach 3.
I'll let you know how it goes.....
27-03-2021 #9
Hi folks
I said I'd let you know how buying direct from CNC Drive went:
I placed an order for a UC400ETH
I quickly received a paypal invoice for 128 euros confirming they were in stock.
I heard nothing for a week so sent an email, it turned out they were out of stock and would be for another week.
After the week I received a DHL email with no useful on it.
I emailed Balazs and he immediately provided a tracking number which showed it was about to be picked up from CNC Drive.
- it arrived the next day! The tracking showed it was flown over.
So if in stock, delivery is super fast. I'd just email them first to confirm an item is in stock.
I've got the UC400 talking to the computer, will connect it to the mill when I've got it safely in a box.
Ian
27-03-2021 #10
I would be interested if you had any import or other taxes added. Thanks
Looking for parallel port cable
By eurikain in forum Computer HardwareReplies: 3Last Post: 20-02-2016, 01:51 AM -
Grounding help, UCCNC, UC300 and connection loss
By gabi68 in forum CNCdrive (UC100, UC300ETH)Replies: 6Last Post: 14-10-2015, 07:42 PM -
parallel port address
By Dan Brown in forum Artsoft Mach (3 & 4)Replies: 6Last Post: 07-01-2010, 12:04 PM -
Laptop, ie no parallel port?
By tompsky in forum Laptops & TabletsReplies: 3Last Post: 11-11-2008, 07:12 PM
