Thread: Strange problem
Page 2 of 2 FirstFirst 12
    I may have nailed the problem down?
    Because I was getting the repeated bad results from the hardware I was using, I decided to change all the electronics again.
    I used a new Arduino UNO, programmed it with the original GRBL 1.1h and then I tried again using the same CNC shield.
    Same problem. So next I also changed the CNC shield for a new one, checked all my wiring very carefully and tried again.
    Same problem.
    I was starting to think maybe the is something wrong in the software, so I opened up Universal G-code Sender and tried that.
    Straight away everything worked, I could home and travel in all directions without any problems.
    So next I closed UGS and opened up LaserGRBL again, and tried again. Back to the same problem, so to me it is something that LaserGRBL is doing.
    Problem confirmed. I loaded an old version of LaserGRBL and it works perfectly, so the new version has a jogging problem.
    I bet you swore at that point :)
    Still swearing, still not fixed as it is a software problem!
  1. Spoilboard surfacing - strange problem/result
    By Nealieboyee in forum Gantry/Router Machines & Building
    Last Post: 30-04-2019, 09:11 PM
  2. strange goings on
    By Kev2960 in forum Chinese Machines
    Last Post: 19-05-2017, 09:37 AM
  3. Strange problem, possibly missing steps?
    By Philly in forum Chinese Machines
    Last Post: 26-10-2012, 06:36 PM
  4. Z acting Strange
    By m.marino in forum Machine Discussion
    Last Post: 06-03-2012, 09:30 PM
  5. a strange question
    By Dan Brown in forum Programmers Corner
    Last Post: 21-12-2009, 01:00 PM
