Thread: Strange problem
    Is the direction that they now only move in the same direction as they move when homing?
    It may just be that the settings are all screwed until it completes a homing cycle correctly. e.g the machine thinks its in some stupid position, and will only move towards it's expected correct range. Maybe X thinks its at -1000 and knows its only allowed to be -500 to +500, so will only move +ve until it thinks it reaches -500.
    First thing to try is disabling soft limits. That should prevent the system babysitting your positioning.
    Do you think this could be a software problem or a firmware or hardware problem?
    Can move in all correct directions right up until I do a homing. The homing completes in the correct way, but after that I can only move in positive directions.
    Quote Originally Posted by regpye View Post
    Can you post the config file as that will help,otherwise we are just stabbing in the dark.
    Good point; Here it is:
    $0=10 (Step pulse time)
    $1=25 (Step idle delay)
    $2=0 (Step pulse invert)
    $3=5 (Step direction invert)
    $4=0 (Invert step enable pin)
    $5=0 (Invert limit pins)
    $6=0 (Invert probe pin)
    $10=19 (Status report options)
    $11=60.000 (Junction deviation)
    $12=0.002 (Arc tolerance)
    $13=0 (Report in inches)
    $20=0 (Soft limits enable)
    $21=0 (Hard limits enable)
    $22=0 (Homing cycle enable) I turned this off to do further tests.
    $23=3 (Homing direction invert)
    $24=1200.000 (Homing locate feed rate)
    $25=1000.000 (Homing search seek rate)
    $26=144 (Homing switch debounce delay)
    $27=3.000 (Homing switch pull-off distance)
    $30=1000 (Maximum spindle speed)
    $31=0 (Minimum spindle speed)
    $32=0 (Laser-mode enable) I turned this off so I could test the laser without motion
    $100=40.000 (X-axis travel resolution)
    $101=40.000 (Y-axis travel resolution)
    $102=80.000 (Z-axis travel resolution)
    $110=10000.000 (X-axis maximum rate)
    $111=10000.000 (Y-axis maximum rate)
    $112=1000.000 (Z-axis maximum rate)
    $120=1000.000 (X-axis acceleration)
    $121=1000.000 (Y-axis acceleration)
    $122=100.000 (Z-axis acceleration)
    $130=840.000 (X-axis maximum travel)
    $131=420.000 (Y-axis maximum travel)
    $132=75.000 (Z-axis maximum travel)
    To me its strange that there seems to be no individual setting for X and Y inverts etc.
    re
    $3=5 (Step direction invert) ... Is 5 the correct number ? I would have thought 0 or 1 !!
    $20=0 (Soft limits enable) ... Is this enabled or disabled ?
    Sorry I don't know much about GRBL
    re
    You need to view the table that comes with GRBL to work out that question about $3=5 It is actually settings for reversing the XYZ motor directions without having to physically doing it with the wiring.
    anything equal to =0 means disabled, =1 is enabled , other numbers are from the table above and are used in several of the settings.
    Ah but the table did not show up in my crystal ball
    I may have nailed the problem down?
    Because I was getting the repeated bad results from the hardware I was using, I decided to change all the electronics again.
    I used a new Arduino UNO, programmed it with the original GRBL 1.1h and then I tried again using the same CNC shield.
    Same problem. So next I also changed the CNC shield for a new one, checked all my wiring very carefully and tried again.
    Same problem.
    I was starting to think maybe the is something wrong in the software, so I opened up Universal G-code Sender and tried that.
    Straight away everything worked, I could home and travel in all directions without any problems.
    So next I closed UGS and opened up LaserGRBL again, and tried again. Back to the same problem, so to me it is something that LaserGRBL is doing.
  1. Spoilboard surfacing - strange problem/result
    By Nealieboyee in forum Gantry/Router Machines & Building
    Last Post: 30-04-2019, 09:11 PM
  2. strange goings on
    By Kev2960 in forum Chinese Machines
    Last Post: 19-05-2017, 09:37 AM
  3. Strange problem, possibly missing steps?
    By Philly in forum Chinese Machines
    Last Post: 26-10-2012, 06:36 PM
  4. Z acting Strange
    By m.marino in forum Machine Discussion
    Last Post: 06-03-2012, 09:30 PM
  5. a strange question
    By Dan Brown in forum Programmers Corner
    Last Post: 21-12-2009, 01:00 PM
