Thread: 3d touch probe
>>> I got an old Renishaw MP1s for something like £160 and fitted a cable to it (originally wireless).
Muzzer - could you say a bit more about this please. Off-the-shelf cable? Is the pin-out fairly obvious? You had an 'MI5 interface unit' already or you managed without this somehow?
Alan
21-10-2021 #2
It's dead simple. The connector is revealed when you remove the inductive pickup head, at which point you discover it's just an old fashioned 5-pin DIN plug, just like we used to use on audio equipment. The circuit is just a normally closed (NC) contact that opens when the tip is displaced. It's a doddle to reconnect. In my case I also fitted a loopback wire so that my (Centroid) controller could see if the probe was present and thus prevent heroic / expensive moves if it was.
Best thing I bought for my mill, improved my accuracy massively, although it simply shows how much backlash I have on the axes.....
Have a look: https://mightyshiz.blogspot.com/2018...inductive.htmlLast edited by Muzzer; 21-10-2021 at 02:05 PM.
23-10-2021 #3
23-10-2021 #4
My Renishaw has a cable, so I have to plug it in each time I need to set something up on my machine. That's a PITA but it allows excellent setup which is more accurate and repeatable than a mechanical edge finder or (Haimer clone) 3D indicator. Overall I can't complain!
Another solution would be an add-on wireless adaptor like the Xoomspeed product https://shop.xoomspeed.com/products/...11877005295663
Bear in mind you need a probe in addition to the wireless kit. He developed this so that he could use his probe in a Tormach ATC.
Touch probe and MT3 tooling
By komatias in forum Classified Ads, Buy, Sell & SwapReplies: 3Last Post: 07-02-2016, 03:51 PM -
Touch Probe Project
By Washout in forum Tool & Tooling TechnologyReplies: 2Last Post: 20-11-2013, 12:59 PM -
Touch probe stylus - where to buy?
By Mad Professor in forum Marketplace DiscussionReplies: 3Last Post: 05-08-2013, 07:07 PM -
Touch Probe
By luke11cnc in forum Probing, Digitizing & ScaningReplies: 28Last Post: 31-01-2012, 01:16 AM -
RFQ: Touch Probe - Lathe job
By cooliced in forum Projects, Jobs & RequestsReplies: 2Last Post: 16-11-2011, 07:12 PM
