Thread: 3d touch probe
  1. Quote Originally Posted by johngoodrich View Post
    Daddy, whats your opinion on that one. The only reason I was looking for uk suppliers is because of import tax etc, and not knowing how much it will actually cost in total
    You have to be careful with that now.
    That Poland one will likely be subject to Import Duty and VAT, as it's over the £130 where eBay are required to process the VAT.
    That is one benefit of the eBay Global Shipping Program. You know exactly what it'll cost before you buy it.
    Thats the issue. It doesn't state what import duties would be, just "may be subject to custo.s duties depending on value"
    >>> I got an old Renishaw MP1s for something like £160 and fitted a cable to it (originally wireless).
    Muzzer - could you say a bit more about this please. Off-the-shelf cable? Is the pin-out fairly obvious? You had an 'MI5 interface unit' already or you managed without this somehow?
    Alan
  4. Please see some our variants.
    PLL005-G2(G3) and PLL006.
    Pumotix.com - > Electronics -> common accessoires
    You can also order them on the weebsites of our EU partners https://www.jbcnc.se/search?query=pll
    or
    https://hardware-cnc.nl/winkel/tools...ouch-probe-3d/
  5. #15
    FYI useful thread on probes here:
    https://www.cnczone.com/forums/torma...4-tormach.html
    Also references a Renishaw presentation here:
    https://resources.renishaw.com/en/de...hnology--54965
    Alan
  6. #16
    Muzzer's Avatar
    Lives in Lytham St. Annes, United Kingdom. Last Activity: 23 Hours Ago Has been a member for 7-8 years. Has a total post count of 460. Received thanks 73 times, giving thanks to others 20 times.
    Quote Originally Posted by alanambrose View Post
    Alan
    It's dead simple. The connector is revealed when you remove the inductive pickup head, at which point you discover it's just an old fashioned 5-pin DIN plug, just like we used to use on audio equipment. The circuit is just a normally closed (NC) contact that opens when the tip is displaced. It's a doddle to reconnect. In my case I also fitted a loopback wire so that my (Centroid) controller could see if the probe was present and thus prevent heroic / expensive moves if it was.
    Best thing I bought for my mill, improved my accuracy massively, although it simply shows how much backlash I have on the axes.....
    Have a look: https://mightyshiz.blogspot.com/2018...inductive.html
  7. #17
    Nice - very clear write-up.
    Thanks, Alan
  8. #18
    I got my mill conversion down to 0.03mm with compensation turned off.
    Not great and even that took some doing to get to that stage.
  9. #19
    Hi
    I have been considering 3d probes myself, thinking of getting one for my new machine when its ready. I will have ATC spindle so should be able to leave the probe in a toolholder all the time.
    Looked at a the ones linked above which look good but was thinking wireless would be a better option I thoght this one looks ok and not silly expensive
    https://vers.by/en/touch-probes/29-vers-wlr.html
    Also this one which is cheap and has a magnetic connector which might be good. https://topcom.cz/dig3dlpm/DIG3D-LP-M-p262128333
    I guess you just run the wire near the spindle and plug it in each time you use the probe.
    Do you guys who have probes just have them on a loose wire or a quick connector?
    Makes me think it would be great to use some kind of Lidar system on the machine for recognizing the material instantly, saw a demo of ipads with it built in for scanning rooms in 3d.
    Ollie
  10. #20
    Muzzer's Avatar
    Yes, that's pretty good in reality. There are buckets of BS on forums and Pootube where armchair machinists claim to "hold tenths" or better on their machines.
    My Shizuoka was a very good quality machine when it was made, with top end HSK ballscrews and bearings and cost more than an average house yet they "only" claimed accuracy of 0.01mm. Clearly with the passage of time and without a professional to set it up, I won't get close to that. In practice I'd probably be happy with 0.05mm and TBH, I don't expect there are many things I'd make that would require much better precision.
    Part of the skill of designing stuff is taking into account the facilities at your disposal. I'm not expecting to be a pub legend any lunchtime soon!
  1. Touch probe and MT3 tooling
    By komatias in forum Classified Ads, Buy, Sell & Swap
    Last Post: 07-02-2016, 03:51 PM
  2. Touch Probe Project
    By Washout in forum Tool & Tooling Technology
    Last Post: 20-11-2013, 12:59 PM
  3. Touch probe stylus - where to buy?
    By Mad Professor in forum Marketplace Discussion
    Last Post: 05-08-2013, 07:07 PM
  4. Touch Probe
    By luke11cnc in forum Probing, Digitizing & Scaning
    Last Post: 31-01-2012, 01:16 AM
  5. RFQ: Touch Probe - Lathe job
    By cooliced in forum Projects, Jobs & Requests
    Last Post: 16-11-2011, 07:12 PM
