    Hi
    I have been using HSS parting tools but need a tool with a smaller tip width (2mm) for parting off (tubes mainly) but also some simple grooving. (I don't need to do any profiling with it.)
    However I am limited on the travel of my ATC and therefore need a tool with as short a head length as possible; ideally 30mm. I have an external position in the ATC that can accommodate a 8mm square shank and was looking at the following but these are slightly too long (35mm and 37mm respectively.):
    Might anyone be able to suggest some alternatives they are using?
    https://www.glanze.co.uk/product/gla...-shank-775200/
    https://www.arceurotrade.co.uk/Catal...g-Tool-Holders
    Lives in East Lothian, United Kingdom. Last Activity: 1 Hour Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    The 8mm shank greatly limits your options. 12mm is where options start to noticeably increase.
    MGxx holders have to be that long for the clamp to work.
    GTN holders have shorter heads, but the smallest shank I can find is 10mm - https://www.shop-apt.co.uk/part-off-...0mm-shank.html
    Non-carbide holders can however be machined down pretty easily with a suitable cutter.
    I'm using an APT tool from this series
    https://www.shop-apt.co.uk/external-...serts-apt.html
    with an insert for grooving, parting and profiling Stainless and difficult materials, so far the first edge has grooved, profiled and parted off around 250 Titanium 6AlV4 parts
  4. The Following User Says Thank You to magicniner For This Useful Post:
  1. FOR SALE: CNC Carbide Wood Lathe Tools with Changeable Cutter Head
    By LeonBlack in forum Items For Sale
    Last Post: 30-04-2020, 11:07 AM
  2. Breaking carbide tool
    By Maxomous in forum Tool & Tooling Technology
    Last Post: 05-04-2020, 09:43 AM
  3. Bits for MDF doors grooving on a 1/2 shank ?
    By Boyan Silyavski in forum Marketplace Discussion
    Last Post: 16-06-2019, 12:13 AM
  4. Threading V grooving tool needed
    By howser37 in forum Tool & Tooling Technology
    Last Post: 31-01-2017, 03:22 PM
  5. Parting off
    Last Post: 14-08-2015, 06:56 AM
