02-04-2021 #3
To be honest, I haven't had any chip welding while using flood coolant. Even if the cutter is running through a pile of chips it sounds grainy and generally to be avoided but it hasn't actually damaged the bit so far. The flood coolant is not as good at removing the chips in a deep slot though, when compared to an air pressure feed. Unless the coolant is pumped into the slot at high pressure, which makes a massive mess of the enclosure, the chips kind of sink in a pool at the bottom of the pocket / slot.
As for the step downs, I'm pretty new to this and am being very conservative on cutting depth. I won't go more than 1mm cut depth for a slot. As I'm not cutting for cash, I don't mind high cycle times and although my machine is capable of cutting deep pockets in Al, I don't want to risk any more carbide cutters.
Help for MOTOR 2.2 Kw and control board optimum BF46 milling machine
By BILLYBOUM in forum Optimum Milling MachinesReplies: 30Last Post: 07-02-2023, 05:02 PM -
RFQ: Batch of 20mm diameter by 30mm aluminium lathe parts
By m_c in forum Projects, Jobs & RequestsReplies: 0Last Post: 08-05-2020, 10:04 PM -
Any tips for deep slots/profiling in aluminium?
By m_c in forum Metalwork DiscussionReplies: 9Last Post: 18-04-2014, 12:00 AM -
FOR SALE: milling slot cutter 20mm new for sale
By chalfontcrew in forum Items For SaleReplies: 0Last Post: 04-02-2013, 12:18 AM -
optimum diameter???
By m.marino in forum Lead Screws, Nuts & SupportsReplies: 4Last Post: 02-04-2010, 12:44 AM
