    Hi!
    I got some closed loop nema 23 steppers (3x 3N and 1x2.2N), with drivers and I'm not 100% sure wich PSU choose.
    This ones:
    https://es.aliexpress.com/item/33056...584063c0ZzRVQU
    Drivers are rated Vdc 24V-80V. The seller told me they use 24/36V 360W for two motors but reading the forum seems like using the higher voltage is better.
    So I was thinking to buy 2x 70V 400W. This ones:
    https://es.aliexpress.com/item/10050...c006H6V4p&mp=1
    Any recomendations? Thanks!
    Quote Originally Posted by Trefhi View Post
    Hi!
    This ones:
    For 2 steppers I'd go 72V 500w per pair. But that's just me. Well, if it's only using 50%-70% it'll likely never fail on you :)
    I run 60V on a basic open loop but have a 350w on each. Been working for years on my 25 size mill.
    I've ordered a 60V 720w single unit now to save space in my new control box and I'm upping to a 72V 400w for my Z motor for an extra boost.
    The 60V 350w ones will prob move to my sieg x2 rebuild at a later date. There's 36v on that machine atm and it's crap!!!!.
    Clive S's Avatar
    Lives in Marple Stockport, United Kingdom. Last Activity: 21 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,347. Received thanks 620 times, giving thanks to others 89 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Hi!
    This ones:
    Personally I would use a toroidal with 3 caps and a rectifier this much better than a switch mode supply.
    25-25 secondary in series will give about 68v DC when rectified.
    Edit: 500 or 625Va would be more than enough for the toroidal.
    What Clive said.
    That's if you're confident and competent.
    I'm not so, otherwise I'd have everything on a 1kw 70v unit :(
  1. New to CNC- need some help choosing a machine
    By jjpltd in forum Machine Discussion
    Last Post: 06-11-2021, 09:46 AM
  2. Replies: 12
    Last Post: 12-11-2020, 09:23 PM
  3. Choosing right CNC
    By rockstardmtb in forum Machine Discussion
    Last Post: 09-04-2019, 09:59 AM
  4. need help! choosing right kit
    By msacnc in forum Gantry/Router Machines & Building
    Last Post: 17-09-2014, 09:41 AM
  5. choosing a spindle.
    By charlieuk in forum Spindles & Drive Motors
    Last Post: 16-01-2014, 08:18 AM
