    From the little I know about ballscrews it would take a lot to persuade me to dismantle them.I think I would first pump quite a bit of grease through them to flush out anything that shouldn't be there and I might do it more than once and in slightly different positions.If it didn't improve things I think I would watch several youtube videos before even contemplating dismantling and I would take careful note of any warnings.I would only do the job on a large and clear bench with some kind of rail surrounding it for restraining escaped components.The sequence of balls may be important as I have read accounts of sizes being intentionally varied along the assembly and the variations are tiny,but necessary so that you don't get a situation akin to a line of balls trying to move but effectively having their neighbours walking on their heels and impeding free motion.
    It would be much easier to clean the threads themselves very thoroughly prior to any form of dismantling and this might pick up any particles that have been attracted to the protective grease that would have been applied for initial assembly and transportation.If you are lucky it might be enough to help but as you have discovered a 5mm pitch is a bit fine for the intended use.
  2. The Following User Says Thank You to routerdriver For This Useful Post:
  3. #2
    Don't waste your time with greasing as it will make no difference and at best only mask the problem, at worst it will mix with what's grinding now and turn the grease into a very nice grinding paste.!! . . Stripping and cleaning ball-screws is a piece of cake and doesn't take long. BUT you must be set up and prepared.
    It's a must that you take them apart in a container with reasonably high sides and if the container is steel place something like a kitchen roll in the bottom to stop the balls from bouncing because they have a habit of shooting off like bullets if dropped from any height. DONT put a magnet near them because you'll just magnetize them and make them attract every speck of metal dusty within a 4mile radius...
    Regards the rotating nut then I've done a few now and you need at least 25mm pitch and then put a ratio on the ball-nut of 3:1 or 2:1 to get the nut rotation speed down. If using 32mm screws then I'd go with 32mm pitch as it's a common pitch size.
    I wouldn't continue with those 5mm pitch screws as you will destroy the ball nut within weeks if you try to spin at anything like 3000rpm, even 2000rpm will eat the plastic tubes away in no time which then causes the balls to jam and stick turning them into 50p pieces as they slide rather than rotate. Cut your losses and sell them on because you will destroy them.
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
  5. Hey JazzCNC. That sounds like very good advice. I plunged on and took the nut off!
    I actually managed not to lose any ball bearings. Good call on the non-bouncy surface ;)
    Didn't have a lot of time today but will make a small vid of the process - once I have successfully put it back together, that is!
    Before Taking it off, I could feel with my hand that there was a little side to side play in the nut, though I couldn't detect any axial play that would obviously translate straight into backlash. Anyway, it made me suspect the balls are slightly undersized.
    Agree, I probably am better off selling them and going to a higher pitch. What is your experience with cheap Chinese ones vs the branded,JazzCNC? 32mm pitch seems a lot, but I see that it does seem popular to match pitch to dia...
    As a side note, the ball diverters are actually metal.
    Thanks again for all your thoughts, keep em coming.
  6. #4
    Quote Originally Posted by Bongo View Post
    Depends where you buy from in China.? Chia's ball-screws where you bought those from are far inferior to those Fred at BST sell's.!
    Also branded is a loose term because like most things there are good and not so good brands, Then you have to consider that you are actually trying to compare apples with oranges because it's not realistic to expect something that cost's $20 compared to something which costs $200 to be even close to equal.
    My experience is that Branded screws are far superior to Chinese screws which is what I would expect given they cost 3 to 4 times the price.
    However, my experience also shows me that even for relatively heavy hobby/light industrial use the better Chinese ball-screws are more than good enough for a CNC router provided you accept that they are not going to last forever and at some point, down the round, they will need replacing. But when you consider you could probably buy 4 sets for the price of one single new THK C5 ground screw this isn't such a bad thing for a hobby user or small business who can afford a little downtime.
    End of the day you have to be realistic.!
    Re the 32mm pitch, with a 3:1 ratio the pitch is equal to 10mm or 16mm with 2:1 however the rotation speed drops from 3000rpm to 1000rpm which is better for the ball-nut.
    However, there is a price to pay in that the torque is reduced, but this is offset some by the ratio increasing torque. But for this application lowering the rotational speed is more beneficial than losing a little torque when you have more than enough spare.!
  8. Thanks for this Jazzcnc, good advice.
    The 'quick method' posted above in the youtube vid, didn't really work for me because getting a 2.5m long ballscrew vertical and then being at the top, in a convenient place see clearly into the nuts and spoon the bbs in seemed troublesome...
    So yeah, after cleaning everything up with lots of brake cleaner (it was reasonably grubby in there), I used the grease dabs to 'stick' the bbs in place. I'm surprised at how well that worked! :D Did it over a
    cardboard box lined with paper towel. Miraculously, number of bbs lost = 0.
Name:	box catcher.jpg
    Upon reassembly, I realized how poor the 'wiper seals' are. Just pieces of hard white plastic that don't seem to fit very well, and that get slightly deformed by the two grub screws holding them in place. They leave a thick layer of grease from inside the nut, very much ALL over the screw outside the nut, where it will attract dust & debris. Has anyone made their own seals for these ??
    Anyway, it's now MUCH less gritty and rolls well. Still has noticeable lateral play mind you... As you say Jazz I think I should cut my losses.
    I messaged Fred on Aliexpress. I was considering a double-nut to remove backlash, but looks like he can't do that on 3232 only 3210. Any experience or opinions on using a double nut for such a large x axis? When I asked about c5 screws Fred mentioned 'TBI' ground and TBI C5 Rolled' ballscrws. I'll admit, I have no idea what "TBI" means - anyone?
    Ok thanks again guys.
  9. #6
    TBI are a Taiwanese manufacturer (Gten are another), from what I've heard they have quite a good reputation, go here:
    https://www.tbimotion.com.tw/en/category/index.html
    Fred quoted me on some and they seemed to be about 60% more expensive than his normal ones, but it might vary with the type of nut you have.
  10. #7
    Pointless going with double nuts for a router, esp one this size, the material, and the error or flex you'll have in the machine will far outweigh any error you'll see from the nut.
    Also, depending on the rotating ball nut design the longer length of the nut could cause issues. Remember you will now be spinning the nut and at high speed, so a longer nut with the flange on the end of the nut will resonate more, the shorter the better really.
    This is another reason for using 32m pitch because it's designed for high speed and uses a nut design that suits high speed better by placing the flange in the middle of the nut and recirculating the balls on both sides of the head flange. For a rotating nut, this is very important as it's much better balanced.
    TBI is a reasonable quality ball-screw manufacturer and if you can afford the extra they are worth investing in. Ground screws are light years better than rolled but they also come with prices that can be out of this world on the higher grades.
  11. The Following User Says Thank You to JAZZCNC For This Useful Post:
  1. Rotating Ball nut
    By drumsticksplinter in forum Lead Screws, Nuts & Supports
    Last Post: 12-05-2020, 08:01 PM
  2. BUILD LOG: Rotating Nozzle
    By Peter3102 in forum DIY Router Build Logs
    Last Post: 25-11-2019, 11:09 AM
  3. WANTED: Rotating Nut Fixture x2
    By PaulP in forum Items Wanted
    Last Post: 02-01-2018, 10:50 PM
  4. Rotating ball nut
    By D-man in forum Projects, Jobs & Requests
    Last Post: 21-03-2015, 08:39 AM
  5. BUILD LOG: New build.Stell frame cnc 1500X1000.Ball screw and gearing calculations
    Last Post: 03-09-2013, 10:37 PM
