  1. #12
    Muzzer's Avatar
    Lives in Lytham St. Annes, United Kingdom. Last Activity: 5 Hours Ago Has been a member for 8-9 years. Has a total post count of 489. Received thanks 81 times, giving thanks to others 26 times.
    Good to see you succeeded!
    Can you fit some of those telescopic covers in your machine setup? I bought some from AliExpress recently for my lathe - they are available in a wide range of diameters and lengths. My Shizuoka had them from new and nothing gets close to the ballscrews.
    https://www.aliexpress.com/item/2040...41a84c4dNrCmN6
    The part numbering system is Dmin-Lmax-Lmin-Dmin where the Dmin and D max are the diameters of the ends of the telescopic springs. Lmax and Lmin are the max and min lengths. For my machine I got a couple of 20-600-40-36 (you need 2 per ballscrew usually).
  2. The Following User Says Thank You to Muzzer For This Useful Post:
  1. Rotating Ball nut
    By drumsticksplinter in forum Lead Screws, Nuts & Supports
    Last Post: 12-05-2020, 08:01 PM
  2. BUILD LOG: Rotating Nozzle
    By Peter3102 in forum DIY Router Build Logs
    Last Post: 25-11-2019, 11:09 AM
  3. WANTED: Rotating Nut Fixture x2
    By PaulP in forum Items Wanted
    Last Post: 02-01-2018, 10:50 PM
  4. Rotating ball nut
    By D-man in forum Projects, Jobs & Requests
    Last Post: 21-03-2015, 08:39 AM
  5. BUILD LOG: New build.Stell frame cnc 1500X1000.Ball screw and gearing calculations
    Last Post: 03-09-2013, 10:37 PM
