    Hi!
    I’m unsure of what couplings to use. As it seems I will go with alu couplings with a slit in them. Any thoughts about that?
    I’ve noticed that the ball screws are round at the end. Is there any reason that they don’t have a flat surface as the motors has?
    I’m thinking that maybe if something goes wrong they will come loose and prevent further damage.
    Thanks, JW
    No, they are the worst coupling to use. you are better using an Oldham-type coupling like this.
    http://www.fbtmotion.com/html/16.html
    Or better still a disc type coupling like this
    http://www.fbtmotion.com/html/17.html
    Regards the ball screw then just file a small flat onto the shaft, the machined portion is soft enough to file.
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
    Thanks!
    I guess the coupling is flexible above a certain amount of torque right?
    Quote Originally Posted by JW1977 View Post
    Thanks!
    I've snapped 3 of those metal 'flexible' couplings so far.
    I now use the spider type with no problem at all.
  5. The Following User Says Thank You to dazp1976 For This Useful Post:
  6. #5
    Thanks!
    It's all to do with parallel and Angular misalignments and to a lesser degree axial growth or misalignment.
    Read this it will explain the different types and Torque ratings etc.
    https://www.thomasnet.com/articles/h...oupling-types/
  8. #6
    *JAZZCNC*
    Do you have any idea or an example of how much runout that can be accepted in a ballscrew?
    Offcourse its hard to answer and its related to length but i was thinking that maybe you have a general idea?
    Im asking because i had some of mine modified in the ends for different reasons. The guy who did it is an experienced machinist used to high precison machines so i guess that in his world my screws are pretty bent. I dont remember exactly but i think that my 900 mm screw where off by 0,4 mm. Im gonna check for myself when i get it back but i think the measure he referred to was when the screw was laying flat and you measure from the flat surface up to nearest point of the screw...
  1. 3040 machine - Which axis has the flexible couplings?
    By DaveMorris in forum Chinese Machines
    Last Post: 30-09-2015, 08:42 AM
  2. Best Place To Buy Couplings?
    By Carlb1058 in forum Marketplace Discussion
    Last Post: 16-04-2013, 02:54 PM
  3. Stepper shaft couplings - can you ID these?
    By HankMcSpank in forum Stepper & Servo Motors
    Last Post: 15-04-2012, 03:46 PM
  4. To usb,or not to usb,that is the question.
    By Jumbo in forum General Discussion
    Last Post: 17-10-2011, 09:21 PM
  5. question ...
    By Wobblybootie in forum General Discussion
    Last Post: 04-01-2010, 12:04 AM
