Thread: PWM output on CNC BOB
12-05-2021 #26
Those relays can be a bit of a chore. I never used it due to hearing it clicking away on startups.
There is a jumper next to the relay, so:
What I did is change the jumper setting so it uses pin17 screw terminal instead of the onboard relay for spindle on/off.
Got a seperate 5v relay with NO/ COM /NC contacts and hi/low trigger option and conect it to pin 17 output.
When PC is off mine sits in NC position. It will not trigger unless it has signal. Spindle switch is connected to NO. It only turns on spindle if Mach activates pin17 via 'spindle on/off'' button. It will NOT come on unless pc is on with mach running.
This will solve the problems.
I actually have a servo drive for mine. It's setup as: Pin17 is my on/off, Pin16 is my direction control.
Relay like this one below.
https://www.amazon.co.uk/Electromech...732588&sr=8-19
You can get them cheaper, this was just for quickness. Made more sense to me to buy multiple channel ones.
Being able to choose between high or low trigger I found quite useful.
Mine is an eight channel module. I have a few things with 5v negative to the trigger (jumper low). Also have a few things with 5v positive to the trigger (jumper high). Everything works perfectly with either polarity acting as triggers (as long as you set the jumper correctly). Great versatile little units :)
Question on Servo power output.
By Zadig in forum General DiscussionReplies: 6Last Post: 24-08-2017, 01:13 PM -
Output voltage from mains driver?
By JW1977 in forum Motor Drivers & ControllersReplies: 8Last Post: 24-03-2017, 01:33 PM -
Output direct to machine
By picyman in forum VectricReplies: 4Last Post: 16-02-2014, 11:04 PM -
HPGL driver output
By 2006Nobull in forum Computer SoftwareReplies: 6Last Post: 07-10-2012, 08:49 PM -
2 Machines 1 Switch for the output - Connections
By Ian Hart in forum General ElectronicsReplies: 7Last Post: 02-04-2010, 02:33 PM
