    good afternoon
    My self-made MACH3 router makes incorrectly shaped roundings ~ 0.25 mm. Have any of you encountered such a situation. This is shown in the connected image.
    Sorry for the language - I translate with GOOGLE
    Indulis Click image for larger version.
Name:	manufacturing error.jpg
    Maybe it's because of back lash, or the machine is not squared properly. Can also be caused by the software sending the step signals or even in the g-code. Are you using accurate steps or rounding corners? Can you post the g-code?
    The axes X Y are perpendicular.
    Baklash is not larger than 0.05 mm
    I use Hybrid Servo Drive HBS86H for drive.
    I use POKEYS 57E for control.
    I also added control from the LPT port, but the error did not decrease
    (Toolpaths used in this file:)
    (Profile 1)
    (Tools used in this file: )
    (1 = End Mill {12 mm}kokam)
    N100G00G21G17G90G40G49G80
    N110G71G91.1
    N120T1M06
    N130 (End Mill {12 mm}kokam)
    N140G00G43Z20.010H1
    N150S16000M03
    N160(Toolpath:- Profile 1)
    N170()
    N180G94
    N190X0.000Y0.000F2000.0
    N200G00X-39.000Y-37.000Z20.000
    N210G00Z2.000
    N220G1Z0.000F2000.0
    N230G1Y-7.000Z-5.000
    N240G1Y37.000
    N250G2X-37.000Y39.000I2.000J0.000
    N260G1X37.000
    N270G2X39.000Y37.000I0.000J-2.000
    N280G1Y-37.000
    N290G2X37.000Y-39.000I-2.000J0.000
    N300G1X-37.000
    N310G2X-39.000Y-37.000I0.000J2.000
    N320G1Y-7.000
    N330G00Z20.000
    N340G00Z20.010
    N350G00X0.000Y0.000
    N360M09
    N370M30
    This is my third construction.
    The first is with servomotors and LPT port control.
    It has everything in order with precision.
    The second is with collector servomotors and AKZ250 CONTROL from USB.
    It also has no problems with accuracy.
    But now I am using servo steppers and problems with accuracy are starting ...
    Could it have anything to do with path blending
    G61 G64
    There is currently a constant velocity in the settings.
    I switched to exact stop, nothing changed from it ??? ... Click image for larger version.
    My guess would be movement or deflection of some part of the router.I would suggest you try cutting two identical parts-one using conventional cutting and one using climb cutting and see how they compare.
    The direction of rotation does not affect the result.
    But with increasing processing speed the error increases.
    the servostepper has 200 steps per revolution, the encoder 1000 pulses per revolution.
    HBS86H I have selected 1000 PULSES PER RPM
    There are 250 pulses per mm displacement along X and Y.
  1. Heart shaped trinket box
    By CharlieRam in forum Woodworking Project Showcase
    Last Post: 3 Weeks Ago, 04:23 PM
  2. Replies: 2
    Last Post: 02-10-2018, 07:27 AM
  3. Replies: 47
    Last Post: 13-02-2014, 11:49 PM
  4. Homepage occasionally displays incorrectly.
    By Jonathan in forum General Discussion
    Last Post: 08-06-2012, 09:15 AM
  5. Replies: 5
    Last Post: 15-04-2012, 12:36 PM
