02-05-2021 #21
02-05-2021 #22
02-05-2021 #23
02-05-2021 #24
Yes and No.?
The problem with using the switches to get the square is you are applying twisting forces on the gantry/linear bearings/ball screw combination causing friction that will very quickly rob power and lead to stalls or missed steps and excessive wear.!.
You need to set the gantry as close to square as possible mechanically ie: loosening pulleys and plates etc so there are no twisting forces on the linear bearings and ball screws. So having setscrews rather than key ways allows you to turn the ball-screw and have it spin in the pulley for fine-tuning because the belt pitch won't allow fine-tuning.
Then if required only use the switches for the very fine tuning.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
02-05-2021 #25
02-05-2021 #26
I'd give these a go on the ballscrew end.
Needs a bit more research but I've seen them on aliexpress.
https://www.aliexpress.com/item/4000311379356.html
Edit:
Amazon is much more £
https://www.amazon.co.uk/s?k=clamp+T...ref=nb_sb_noss
The Following User Says Thank You to dazp1976 For This Useful Post:
03-05-2021 #27
IMO The advantages of "taper-lok" and my DIY ER solution is that they are more compact, better concentricity, better grip, no damage to the shaft from grub screws, infinite ajustability and depending on pulley size less mass.
The Following User Says Thank You to johnsattuk For This Useful Post:
Carbide taper ball nose cutters
By Leadhead in forum Tool & Tooling TechnologyReplies: 2Last Post: 08-01-2020, 06:45 AM -
Is there a Lee on eBay from china who is good for ball screws and guides from please?
By suesi34e in forum Rails, Guideways & BearingsReplies: 1Last Post: 13-11-2015, 12:40 AM -
have you put ball screws on an X2plus?
By bmbaz in forum Milling Machines, Builds & ConversionsReplies: 5Last Post: 14-05-2014, 06:56 PM -
buying ball screws
By bmbaz in forum Marketplace DiscussionReplies: 2Last Post: 10-05-2014, 03:57 PM -
Best way to machine ball screws?
By Ross77 in forum Lead Screws, Nuts & SupportsReplies: 34Last Post: 17-06-2012, 05:10 PM
