The short-sighted approach, in my opinion, literally takes 2mins to create a new profile. You are not reconfiguring the machine just making a few simple adjustments to a completely separate profile, his original config isn't affected at all.
Then from that point on no messing around in a separate program is required, you just load the imperial profile when cutting imperial code.!! . . . Simplzzzz-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
NEW MEMBER: Hello from Lincoln UK (Converting Warco WM14, need to learn G-Code or CAD CAM)
By Jools in forum New Member IntroductionsReplies: 12Last Post: 29-11-2020, 03:09 PM -
FOR SALE: Oxford 0-25mn Metric/Imperial Digital Micrometer with SPC
By Caster1 in forum Items For SaleReplies: 0Last Post: 03-01-2016, 08:52 AM -
Converting Imperial fractions to metric. Solution?
By ChrisG in forum Machine DiscussionReplies: 5Last Post: 03-02-2011, 07:11 PM -
Conversion Tables TO - FROM Imperial/Metric
By Lee Roberts in forum Machine DiscussionReplies: 0Last Post: 27-02-2008, 02:08 PM
