Thread: Setting up a Haunyang VFD
I have continuity between pins 1, 2 & 3 but not 4
There is no continuity between 1,2 & 3 and the body
There is continuity between pin 4 and the body (So it's grounded from factory correct?) I was surprised I just assumed it wasn't because they never are
I will solder pin 4 on, which will mean removing the 3 I soldered to get everything the right length again I removed the earth was going to send a separate wire and earth the spindle holder instead.
Since I did a factory reset on the Haunyang it does nothing when I press run but I can access the setting menu
I do have another Chinese VFD I can swap in correct rating an AT1-2200X never been used
What I don't want to do is damage the new spindlehttp://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
Haunyang VFD input voltage
By JamesUS in forum Spindles & Drive MotorsReplies: 0Last Post: 18-01-2015, 08:25 PM -
THC Setting Issue?
By Davek0974 in forum Plasma Table MachinesReplies: 8Last Post: 17-10-2014, 07:53 AM -
Setting my table up...
By Davek0974 in forum Plasma Table MachinesReplies: 23Last Post: 10-03-2014, 08:24 PM -
setting up a business
By dstivens in forum Opportunities Available & SoughtReplies: 5Last Post: 16-05-2013, 10:28 PM -
setting the origin
By Fivetide in forum Computer SoftwareReplies: 9Last Post: 04-02-2013, 12:18 AM
