04-05-2021 #2
Jeff,
Looks good so far, you've obviously put a lot of time and effort in already.
The most obvious weak point you will get picked up on is the gantry. That single piece of upright profile may be too flexible. The current preferred and proven design would have another piece laid horizontally below the one you already show. This will give you much greater rigidity in all directions on the beam itslf and make the fixing of the end plates more rigid. There are pictures of this in various places on the forum.
The only other piece of advice I would offer, especially for a hobby builder with a budget, is to check the standard sizes of materials you can get or if your supplier will do cut lengths. I had a problem with suppliers in Perth, Australia only being willing to supply whole 6m lengths of aluminium sections. This is a real problem if your design only wants 2m of one size or 6.2m of another.
Looking forward to seeing your progress.
KitAn optimist says the glass is half full, a pessimist says the glass is half empty, an engineer says you're using the wrong sized glass.
The Following User Says Thank You to Kitwn For This Useful Post:
BUILD LOG: First Build-Steel Gantry CNC - Comments on design wanted
By olaff in forum DIY Router Build LogsReplies: 13Last Post: 06-12-2015, 08:34 PM -
First build - Mid-scale gantry router design
By Ellis in forum Gantry/Router Machines & BuildingReplies: 8Last Post: 20-05-2015, 11:43 PM -
BUILD LOG: Vertical fixed gantry. Design & build. (Steel/epoxy)
By Greeny in forum DIY Router Build LogsReplies: 8Last Post: 19-08-2013, 08:26 PM -
