I rendered a few more options. Maybe someone can share more insight.
215mm high gantry:
Option 1 (120x80 + 160x40)
This is the closest to what I currently have.
Not really much more expensive. Everything (motors, bearings) still fits neatly behind the gantry.
255mm high gantry:
Option 2 (160x80 + 160x40)
Fairly similar, but 40mm higher.
Option 3 (120x80 + 120x80)
Using identical extrusions.
Option 4 (120x80 + 160x80)
The expensive option.
06-05-2021 #2
The Following User Says Thank You to NB70 For This Useful Post:
06-05-2021 #3
My supplier does offer 45mm (B-Type) extrusions, but the choice is very limited.
Using my supplier, the only sensible option is the one you're showing, using 2 45x90 extrusions for a 90x135 gantry.
I prefer the 40mm (I-Type) extrusions. They're thicker, easier to tap, there's more compatible hardware, and I can get them in larger configurations, such as 160x80 and 120x80.
I don't mind using the FK/FF bearings, but you're definitely right that using BK/BF, bolted directly to an extrusion is both easier and more adjustable.
BUILD LOG: First Build-Steel Gantry CNC - Comments on design wanted
By olaff in forum DIY Router Build LogsReplies: 13Last Post: 06-12-2015, 08:34 PM -
First build - Mid-scale gantry router design
By Ellis in forum Gantry/Router Machines & BuildingReplies: 8Last Post: 20-05-2015, 11:43 PM -
BUILD LOG: Vertical fixed gantry. Design & build. (Steel/epoxy)
By Greeny in forum DIY Router Build LogsReplies: 8Last Post: 19-08-2013, 08:26 PM -
