Thread: Denford stepper motor
14-05-2021 #1
I have a denford microrouter that just been converted to Mach3, everthing seemed to work ok but 5 minutes into the first job it suddenly stopped and the y axis sounded like a machine gun, I tried to move the y axis with the keyboard it won’t move & just keeps making rattling sound, I reset the controller and it started to move ok until it stopped again and made the same rattling sound, could it be the stepper motor at fault or the ball nut, how would I find out which one is is causing the problem, also where could I find replacement parts, Thankyou. Mike
14-05-2021 #2
14-05-2021 #3
Yes oiled well and slides freely, I disconnected the stepper motor and ran a program and it still does it so looks like the motor or wiring may be the problem, do denford still carry spares for old machines ! Regards Mike
14-05-2021 #4
It could be the drive or cabling First is to check with a meter both phases of the stepper post a picture of the drive and connections to the stepper there will be 4 wires to the stepper ie 1 pair for each coil.
It is unusually for a stepper to fail.
Don't unplug the stepper with the drive powered..Clive
14-05-2021 #5
Thanks Clive, it would appear that it is the cable going into the motor, as it moves there must be a break in the wire, it looks like the wiring is connected directly to the windings so not sure if it’s the cable or the thin copper wire on the winding that’s the problem, I’ll have a look tomorrow,
14-05-2021 #6
14-05-2021 #7
15-05-2021 #8
Hi Clive, your advice to not open the stepper motor came to late I’m afraid, but I have checked all wires, and I think the break is in the chain, looks like I’m going to have to replace all the wiring,
15-05-2021 #9-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
15-05-2021 #10
O dear, any idea where I buy a replacement from
Stepper motor I.D anyone?
By Nthkentman in forum Machine DiscussionReplies: 2Last Post: 11-05-2015, 08:03 AM -
How do I wire a stepper driver to a stepper motor?
By swood1 in forum Stepper & Servo MotorsReplies: 7Last Post: 21-09-2014, 05:40 PM -
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
eBay: Denford Triac Parker Digiplan SD2 & SD3 Stepper Drivers
By davidimurray in forum Items On eBay UKReplies: 0Last Post: 25-02-2013, 10:23 PM -
Denford Triac stepper motor
By hudmut in forum Stepper & Servo MotorsReplies: 3Last Post: 14-01-2010, 05:10 PM
