Thread: Weird problem with stepper axis.
Like Jazz said. Rip out all the wires and start all over again, one axis first. But before that, make a wiring diagram and start wiring when that is done and is right. Use the diagram as a guide and mark every wire you have connected. Use a multimeter to check the connection from point to point for every single wire BEFORE trying to run that axis. Don't power it up before that step.
Obviously something is wrong and you have no idea what, so I think also that it's best to start over. Just one more question. Do you use a 25 pin parallel port cable between the UC100 and the bob, or just a short ribbon cable? You could try a different cable just in case...
17-05-2021 #2
Hello
The UC100 plugs directly into the DB25 of the bob.
Great advice, I was becoming impatient after spending weeks on the Gecko.
I will do as you and Jazz suggest and be more methodical.
Many Thanks, Greg
Stepper motor making a weird noise
By GeorgeS in forum General DiscussionReplies: 5Last Post: 09-06-2020, 09:51 PM -
Weird Mach3 + CSMIO/IP-M Probe Problem
By matt-b2 in forum General DiscussionReplies: 24Last Post: 11-07-2019, 01:05 PM -
Help with Problem X axis Stepper Please
By howser37 in forum Gantry/Router Machines & BuildingReplies: 53Last Post: 09-02-2017, 06:31 PM -
Weird problem - stepped/staged deceleration on Huanyang 2.2kw Spindle
By glynster in forum Spindles & Drive MotorsReplies: 0Last Post: 25-01-2016, 01:39 PM -
weird z axis..
By dazza in forum General DiscussionReplies: 5Last Post: 10-11-2014, 01:39 AM
