Thread: NVEM V2 Novusun BIN file
16-05-2021 #1
Anybody can help me to source a bin file (firmware) for Novusun NVEM V2 Ethernet controller? I accidentally loaded firmware for NVUM - usb version.
Everything was OK before wrong firmware uploaded. Now I can't get controller to connect. Not sure whether I can fix it but its worth a try.
There is a link on this site but doesn't work. https://www.nvcnc.net/pdf/nvem.bin.rar
Hello. Do you solve you problem? Do you succeed to write correct firmware?
29-06-2021 #3
No, I haven't solve it. I've contacted the supplier and he said that his technicians are working on solution. I don't have big expectations. Will see. I bought another unit.
29-06-2021 #4
Do you find. Bin file an you fail to write firmware or no get the. Bin file?
29-06-2021 #5
I haven't found a bin file for NVEM.
30-06-2021 #6
30-06-2021 #7
Unfortunately, yes. Another NVEM. Mainly because of size constraints and wiring in place. I did not run the machine yet but run individual axes ok. Spindle with rs485 and also limit switches. All ok.
30-06-2021 #8
Should have looked into the AXBB-E.
30-06-2021 #9
18-08-2021 #10
Palec,
I am looking for the bin file for the usb version.
The download link does not work.
Maybe you can help me with the file for NVUM version 2 USB 6 axis.
Grt Rony
Nvem v2 help
By jmh474 in forum General ElectronicsReplies: 6Last Post: 06-08-2024, 07:08 AM -
Help with .stl file
By johnsattuk in forum General DiscussionReplies: 18Last Post: 14-06-2019, 07:04 PM -
Any experience of Novusun Ethernet motion controllers?
By Doddy in forum Control Hardware & SystemsReplies: 0Last Post: 28-12-2016, 10:50 AM -
File upload problems - attachments file extension support !
By Swarfing in forum General DiscussionReplies: 14Last Post: 08-03-2013, 02:37 PM
