    Anybody can help me to source a bin file (firmware) for Novusun NVEM V2 Ethernet controller? I accidentally loaded firmware for NVUM - usb version.
    Everything was OK before wrong firmware uploaded. Now I can't get controller to connect. Not sure whether I can fix it but its worth a try.
    There is a link on this site but doesn't work. https://www.nvcnc.net/pdf/nvem.bin.rar
    Hello. Do you solve you problem? Do you succeed to write correct firmware?
    No, I haven't solve it. I've contacted the supplier and he said that his technicians are working on solution. I don't have big expectations. Will see. I bought another unit.
    Do you find. Bin file an you fail to write firmware or no get the. Bin file?
    I haven't found a bin file for NVEM.
    Quote Originally Posted by palec View Post
    Not another NVEM I hope
    Don't people read the bad reviews on these things?!.
    Unfortunately, yes. Another NVEM. Mainly because of size constraints and wiring in place. I did not run the machine yet but run individual axes ok. Spindle with rs485 and also limit switches. All ok.
    Should have looked into the AXBB-E.
    Should've looked into the AXBB-E.
    Rony's Avatar
    Lives in Veldegem, Belgium. Last Activity: 18-08-2021 Has been a member for 3-4 years. Has a total post count of 1.
    Palec,
    I am looking for the bin file for the usb version.
    The download link does not work.
    Maybe you can help me with the file for NVUM version 2 USB 6 axis.
    Grt Rony
  1. Nvem v2 help
    By jmh474 in forum General Electronics
    Last Post: 06-08-2024, 07:08 AM
  2. Help with .stl file
    By johnsattuk in forum General Discussion
    Last Post: 14-06-2019, 07:04 PM
  3. Any experience of Novusun Ethernet motion controllers?
    By Doddy in forum Control Hardware & Systems
    Last Post: 28-12-2016, 10:50 AM
  4. File upload problems - attachments file extension support !
    By Swarfing in forum General Discussion
    Last Post: 08-03-2013, 02:37 PM
