    ZASto's Avatar
    Lives in Belgrade, Serbia. Last Activity: 4 Weeks Ago Has been a member for 5-6 years. Has a total post count of 49. Received thanks 1 times, giving thanks to others 1 times.
    BTW, what's an AC or DC servo? There is only one servo, but I think you call AC servo a servo which has a drive connected to AC current and DC servo one which has a driver connected to DC current. The only actual difference is that in one case you have the rectifier built into the driver and in the other case you have it built into the PSU. Mine is called AC servo with integrated driver, which requires 20-50VDC, but it is still an AC servo and not a stepper.
    DC servo is breushed DC motor with attached encoder for feedback.
    AC servo is kind of 3 phase BLDC motor with encoder for feedback.
    Drives for both types of servo motors could, by design, ve connected to AC or DC power source (at the end it is ALWAYS DC source).
    Quote Originally Posted by ZASto View Post
    That's the way I see it as well. But perhaps others see it differently, and that's OK as long as we understand what we mean. Mine is the brushless, 3-phase delta wired motor which I think all AC servos are. As for the drivers, yes, in the end, ALL driven by DC but installation wise it looks easier if you just have to plug one into the mains directly, compared to having to have a large power supply first. On the other hand, if a driver needs like 80VAC then it needs a large transformer and a box anyway, so while building a PSU out of that to provide DC output is a tiny bit more work, but that's really no big deal and in my opinion the benefits are basically gone. But sure, if directly mains driven then it is really nice and neat solution. Unfortunately, those motors are still pretty expensive.
  1. Why is Y axis "squaring" necessary only with twin motors?
    By MartinS in forum Linear & Rotary Motion
    Last Post: 09-08-2017, 10:10 PM
  2. BUILD LOG: "Henge", 3 Axis Cnc, Fixed Gantry, Moving Table
    Last Post: 20-03-2017, 08:43 PM
  3. "Hacking" and "Modding"
  4. Setting up "System 45" 3 axis unit by DIYCNC
    By StevenT in forum LinuxCNC (EMC)
    Last Post: 15-10-2014, 03:22 PM
  5. "Racks" VS "ball screw"
