19-05-2021 #4
Hi Charlie, thanks for the feedback. When designing the machine I considered various issues with possible flex in the various axis. Like you the ability of the gantry to move due to cutting forces concerned me. Although I have not done any complex calcs working through the axis, my logic is......
Z axis - 4 Hiwin carriages on 15 mm rail will easily support 5Kg of the spindle, carriages and plate
X Azis - 4 Hiwin carriages on 15 mm rail, I am using closed sided aluminium extrusion plus the rail, as long as I don't compress the axis when setting up there will be virtually no flex, it needs to support 12kg (see picture of extrusion)
Y axis - again 4 carriages on 15 mm rail, in compression this shouldn't be a problem, the only issue is the sideways cutting forces as you pointed out. I am using 8 mm bolts to attach the gantry plates and they will be embedded in 2 mm pockets as will the carriages and ballnuts. This leaves about 150 mm by 750 mm 'box' shape that has the potential to deflect. I am using 10 mm cast tooling plate. My gut feeling is this will not flex since the cutting forces for a 1 kw spindle will be comparatively light
If there is too much flex I have a couple of get out of jail options
1) add a cross beam, I would prefer not to do this as I am planning to use the space under the machine to house the electronics
2) Add another rail on each side with more carriages, again more complexity, weight and cost
40 mm x 40 mm KJN aluminium extrusion
I am starting to cut soon so I will have to fix the design
Ian
BUILD LOG: Jeff's 1000 x 800 Gantry Router Design & Build
By JeffZ in forum DIY Router Build LogsReplies: 12Last Post: 20-06-2021, 04:50 PM -
Desktop gantry router for hobbyist
By Soyb in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 07-05-2021, 10:08 AM -
BUILD LOG: Desktop type router - Fixed gantry - steel frame MK2
By Tom J in forum DIY Router Build LogsReplies: 14Last Post: 02-01-2017, 09:32 PM -
eBay: 1500 x 1000 router any use ?
By EddyCurrent in forum Items On eBay UKReplies: 3Last Post: 24-12-2013, 12:18 PM
