    Soyb's Avatar
    Lives in Leominster, United Kingdom. Last Activity: 12-11-2024 Has been a member for 3-4 years. Has a total post count of 38. Received thanks 5 times, giving thanks to others 2 times.
    Hi Charlie, thanks for the feedback. When designing the machine I considered various issues with possible flex in the various axis. Like you the ability of the gantry to move due to cutting forces concerned me. Although I have not done any complex calcs working through the axis, my logic is......
    Z axis - 4 Hiwin carriages on 15 mm rail will easily support 5Kg of the spindle, carriages and plate
    X Azis - 4 Hiwin carriages on 15 mm rail, I am using closed sided aluminium extrusion plus the rail, as long as I don't compress the axis when setting up there will be virtually no flex, it needs to support 12kg (see picture of extrusion)
    Y axis - again 4 carriages on 15 mm rail, in compression this shouldn't be a problem, the only issue is the sideways cutting forces as you pointed out. I am using 8 mm bolts to attach the gantry plates and they will be embedded in 2 mm pockets as will the carriages and ballnuts. This leaves about 150 mm by 750 mm 'box' shape that has the potential to deflect. I am using 10 mm cast tooling plate. My gut feeling is this will not flex since the cutting forces for a 1 kw spindle will be comparatively light
Name:	Screenshot 2021-05-19 093712.png
    If there is too much flex I have a couple of get out of jail options
    1) add a cross beam, I would prefer not to do this as I am planning to use the space under the machine to house the electronics
    2) Add another rail on each side with more carriages, again more complexity, weight and cost
Name:	Screenshot 2021-05-19 095343.png
    40 mm x 40 mm KJN aluminium extrusion
    I am starting to cut soon so I will have to fix the design
    Ian
Name:	Screenshot 2021-05-19 095410.png
    Quote Originally Posted by Soyb View Post
    Ian
    It's not so much the deflection as it is the lack of rigidity which will lead to chatter, premature tool wear and tool breakage ect, probably ok for woods but I would imagine you'll struggle cutting aluminium.
    Charlie
    Sent from my M2003J15SC using Tapatalk
    I would consider 10mm pitch screws on X and Y and 5mm on Z
    Soyb's Avatar
    Hi Clive, why larger pitch ballscrews? from a newbie I assumed that 5 mm would give better control, less backlash etc
    Steppers have higher torque at lower speed . Also you will get less whip with a lower speed on the screw
    The pitch has nothing to do with how much backlash you get and everything to do with the speed and resolution. Clive is correct that for a router that will cut a range of materials you are better with 10mm pitch on X & Y as it covers a much wider range of feed rates for the various materials correctly. Also, like Clive says it allows you to keep the rpm down which gives higher torque where you need it, which is when cutting.
    If you are planning on cutting mostly Aluminium then a 5mm pitch would be better as it allows higher resolution, that said 10mm pitch still gives a decent resolution. However, if you are mostly cutting aluminium then you'll need a stronger machine than what you are planning now.
    The design you have now is ok for an all-around machine, though it could use a little beefier gantry sides, it would also benefit from using my "L" shape gantry design which will be much stronger than what you have shown. If you do stay with your gantry design I would drop the plate at the rear on the x-axis carriage as you will find it a pain to set up and doesn't add very much strength.
    I have built lots of machines using a similar design with higher sides and the design is stronger than people realise, so don't let the naysayers put you off because as an all-round material cutting machine they work very well. I also have customers who run very very successful businesses with my machines which are very similar in design.
    Some advice would be to use 20mm rails rather than 15mm as the bearing size is easier to work with and just suits a machine like this better, the cost difference isn't much more and worth the extra. 15mm bearings are fiddly little things.
    Use 15mm plate as a minimum for gantry sides and Z-axis. Remember the Z-axis is the most important area as it holds the cutting tool so if it's weak and vibrates then doesn't matter how strong the rest of the machine is you'll get rubbish finish and excess tool wear.
    DUMP the KRESS, they are toys compared to water-cooled spindles.
    DUMP the KK01 Bob and buy a decent Ethernet motion controller like the AXBB-E and run it using UCCNC, this will be the best investment you'll make.
    Lastly but not as important as the controller but still does make a big difference, I would use higher power drives than 50Vdc and if you can afford it go with closed-loop steppers as they are SOOOO much better than standard steppers.
    Building a good machine is all about the balance of electronics and components along with a strong design, if anyone is weak the machine will suffer.
    Good luck.
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
    Soyb's Avatar
    Added design for housing electronics under the machine, I am going to put a drag chain from the gantry ballscrew to the electronics.
Name:	Screenshot 2021-05-20 103745.png
ID:	29988Click image for larger version.
Name:	Screenshot 2021-05-20 103700.png
    Soyb's Avatar
    Some minor updates, I have decided to use proximity sensors instead of mechanical switches for the limits / homing so Slight change to each axis to have mounting holes
Name:	Screenshot 2021-06-02 141306.png
ID:	30013Click image for larger version.
Name:	Screenshot 2021-06-02 143345.png
ID:	30014Click image for larger version.
Name:	Screenshot 2021-06-02 143632.png
    I have also increased the length of the z axis rails to allow a accommodate 4 blocks and give me ~ 110 mm travel, and redesigned the spindle mounting plate to allow access to the grease nipple on z axis
Name:	Screenshot 2021-06-02 144744.png
    Soyb's Avatar
    I have to admit I had not thought about vibration / resonance, with an open x axis there is a potential for chatter
  1. BUILD LOG: Jeff's 1000 x 800 Gantry Router Design & Build
    By JeffZ in forum DIY Router Build Logs
    Last Post: 20-06-2021, 04:50 PM
  2. Desktop gantry router for hobbyist
    By Soyb in forum Gantry/Router Machines & Building
    Last Post: 07-05-2021, 10:08 AM
  3. BUILD LOG: 8x4 router build. Steel base & Aluminium gantry gantry
  4. BUILD LOG: Desktop type router - Fixed gantry - steel frame MK2
    By Tom J in forum DIY Router Build Logs
    Last Post: 02-01-2017, 09:32 PM
  5. eBay: 1500 x 1000 router any use ?
    By EddyCurrent in forum Items On eBay UK
    Last Post: 24-12-2013, 12:18 PM
