27-12-2023 #31
Hi Tom,
My design ethos was to build a desktop machine with reasonable accuracy, it’s not a production machine but has been used regularly. It is a toy compare to many machines in this forum but it fits my criteria and works well. For a more robust machine I would add extra rails to the Y axis, and re design the X axis so the rails are forward facing and use stronger extrusion, probably a larger C channel. A more robust machine = heavier components = stronger frame = heavier machine etc etc, I had to decide at what point in the design process I had achieved my goals and stop developing / adding complexity. I only had to buy 2 machined parts that I was unable to make, but with a bit of redesign I could remove them to use just flat plate. 2 time around I would make improvesment but still end up with a very similar machine in size / capabilities. Sound like your machine will be similar but a little more robust.
BUILD LOG: Jeff's 1000 x 800 Gantry Router Design & Build
By JeffZ in forum DIY Router Build LogsReplies: 12Last Post: 20-06-2021, 04:50 PM -
Desktop gantry router for hobbyist
By Soyb in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 07-05-2021, 10:08 AM -
BUILD LOG: Desktop type router - Fixed gantry - steel frame MK2
By Tom J in forum DIY Router Build LogsReplies: 14Last Post: 02-01-2017, 09:32 PM -
eBay: 1500 x 1000 router any use ?
By EddyCurrent in forum Items On eBay UKReplies: 3Last Post: 24-12-2013, 12:18 PM
