    I have a 4th axis (and 5th) harmonic drive unit from China and it uses Lichurn nema 34 motors on the 4th and the lichurn driver you have, I've had real trouble running the motor and may have blown up the drive, it runs through an adtech controller, maybe you help me with the driver?
    The driver on it is LCDA 86H and the motor LC86H280 . Can you supply the driver?
    Quote Originally Posted by Sucram View Post
    Yes, I can supply the drive, but how did you blow the drive because they are very robust drives and not easily blown. What voltage did you use.? Running too high a voltage is about the only thing I could see blowing one of these drives.
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
    Got the encoder wires the wrong way round maybe? I'm using 60v ac
  1. Toroidal Transformer for Lichuan 5.5Nm closed loop steppers.
    By handles in forum General Electronics
    Last Post: 06-10-2020, 09:48 PM
  2. Closed loop stepper motor encoder help
    By DenJon in forum Gantry/Router Machines & Building
    Last Post: 23-04-2020, 04:55 AM
  3. Lichuan "Easy Servo" closed loop stepper question
    By Voicecoil in forum Stepper & Servo Motors
    Last Post: 09-10-2019, 09:33 PM
  4. Closed loop stepper motor kit power supply
    By the great waldo in forum Motor Drivers & Controllers
    Last Post: 21-09-2019, 10:08 AM
  5. Closed Loop Stepper Compared with Open Loop Stepper
    By Leadshine-Erci in forum Stepper & Servo Motors
    Last Post: 25-05-2012, 08:11 AM
