  1. #2
    Hi Ernie,
    Well, you don't actually say what size Nema23 motors so it's hard to give an accurate answer. However, I have built several machines which lift the whole gantry like what you are planning that was made from 25mm Aluminium plate and much heavier than your MDF setup using 2 x 4Nm Nema 23 motors with 10mm pitch screws and they didn't even know they were lifting it.
    So if you are using at least 2Nm with a decent amount of volts then I'm 99.9% sure you won't have any issues lifting an MDF gantry.
    This one used a single 4.5Nm Nema 34 Closed-loop motor connected to the 2 x 10mm pitch screws with a belt and a slight ratio of 1:5.
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
  1. will this work
    By erniehatt in forum General Discussion
    Last Post: 17-02-2021, 12:04 AM
  2. Replies: 0
    Last Post: 15-12-2019, 09:44 PM
  3. 4th Axis Work Holding For Rectangular Work
    By magicniner in forum Workshop & Equipment
    Last Post: 20-10-2019, 03:02 AM
  4. RFQ: I am looking for work as cnc operator.
    By krystiankania in forum Projects, Jobs & Requests
    Last Post: 13-02-2014, 03:48 PM
  5. Please help me... It wont work.
    By kingcreaky in forum Artsoft Mach (3 & 4)
    Last Post: 22-01-2014, 10:42 PM
