22-05-2021 #3
Yes, I suspect you're right. Most 230V in / 230V out VFDs don't check for phase voltages, 'cos it really doesn't matter to them. However, the type that boost 230V in to 415V out have front end which might get upset if a phase were missing if they use a 3-phase boost power factor corrector (PFC) front end.
I've avoided the need for one of those 230-415 VFDs but it must be possible to find some that DO run on single phase because I've seen a few recommended on various forums.
Sounds as if Jazz knows of some examples.
A simpler solution would be to either modify your existing motor for 230V delta connection or replace it with a 230V motor. Then you can use almost any 230V VFD. That may work out cheaper in the long run, as a boost VFD is going to cost you more.
Help requested - installing end stop sensors onto my chinese 3018 Pro
By favouritesky in forum Chinese MachinesReplies: 23Last Post: 06-12-2020, 06:08 PM -
mach3 wont reset keeps saying external emg stop requested
By Geoff57 in forum Boxford LathesReplies: 49Last Post: 02-04-2020, 05:51 PM -
REBUILD: Hardinge HC rebuild
By northumbrian in forum Lathe Rebuild LogsReplies: 29Last Post: 21-02-2017, 12:07 PM -
Advice requested for these products and any suggestions; Links below
By mordy in forum Motor Drivers & ControllersReplies: 26Last Post: 14-06-2015, 01:49 PM -
Cutting bits nomenclature - help requested
By DanielF in forum Tool & Tooling TechnologyReplies: 2Last Post: 12-05-2012, 04:53 PM
