Thread: Auto-Squaring UCCNC
I'm with you 100% on getting the basic mechanism squared within a fine tolerance and that doesn't just mean using two motors with separate homing and tweaking the position of the sensors as I wrongly suggested above. Having given this some more thought, the accurate matching of the position of the two homing sensors is also critical in maintaining squaring and preventing strain on the machine. Errors in sensor position will strain and twist other components in exactly the same way as adjusting the back off distance. I don't recall seeing this stressed in past discussions of using two motors with separate homing. What matters is that the gantry must sit square on it's bearings and relax naturally into something very close to the correct alignment before we start doing any homing. The sensors then need to be placed to maintain this alignment when the two motors stop during homing and adjustment of back off distance then used to correct the last sub-millimetre errors.
I'd suggest that the correct sequence of alignment for this kind of machine is:
With motors disabled let the gantry relax into it's natural position.I check this by disabling the motors and manually turn one screw while holding the other one fixed. You soon feel one screw tighten up and can set the central relaxed position.
Re-enable the motors (without doing a new homing sequence!) and check squareness. Adjust the gantry mountings until you're as close as you can get.
If you're not confident of the accurate matching of your two sensor positions try creeping the machine towards the sensors and check they trigger at the same time. Adjust as required.
Only now should you use tweaks of back off distance to correct remaining sub-millimeter errors which could be in the gantry or the relative sensor positioning.
I had a quick go at aligning my machine today and needed a noticeable shift of the gantry on it's mountings to get good alignment in the relaxed position before homing. I didn't check the sensor positions but ended up with the back off distances different by 0.5mm which is well within the strain tolerance of the round rails I'm using and suggests the sensors are not too far out.
The as-bulit homing in UCCNC is less flexible than in LinuxCNC but doesn't need quite as much reading of the instructions to get it working. I particularly liked the Linux way of moving quickly onto the sensors to find them in a short time then backing off a few mm and moving on again more slowly before the final back off. This makes homing both quick and accurate. As it must be the best part of 20 years since I had a brief play at programming in C# I'm not about to try and Make UCCNC do the same, though I'm sure it's possible.
KitAn optimist says the glass is half full, a pessimist says the glass is half empty, an engineer says you're using the wrong sized glass.
Auto-Squaring with LinuxCNC v 2.8
By Kitwn in forum LinuxCNC (EMC)Replies: 12Last Post: 25-04-2021, 01:25 AM -
Idea: Module for gantry squaring of slave axis with standalone controller
By devmonkey in forum Control Hardware & SystemsReplies: 2Last Post: 26-11-2019, 04:25 PM -
Why is Y axis "squaring" necessary only with twin motors?
By MartinS in forum Linear & Rotary MotionReplies: 10Last Post: 09-08-2017, 10:10 PM -
Setup for squaring twin X-axis gantry
By routercnc in forum Gantry/Router Machines & BuildingReplies: 20Last Post: 26-03-2014, 11:13 PM -
Seeking some practical squaring advice.
By Wal in forum Gantry/Router Machines & BuildingReplies: 12Last Post: 09-01-2014, 12:04 AM
