Thread: Micro steps
That's not a good way to think of it and poor advice.! . ... Micro steps shouldn't be thought of or used to gain resolution, that's the purpose of the pitch of lead or ball -screws or whatever method you use for linear motion and any ratios which are applied.
Most steppers can't resolve resolution much past 2000ms so anything after that is wasted in terms of resolution gains and then all you are doing is losing torque and stressing the motion controller, yes you gain a little smoother motion from the steppers but still not worth it and the high pitch noise is horrible.
No stepper really needs to be run past 2000ms and if small motors I'd recommend you don't go past 800 to keep all the torque you have, my preference is 1600ms for 3-4nm nema 23/4 motors but this varies depending on motor and drive combo's and how well they handle resonances, etc.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
01-06-2021 #2
02-06-2021 #3
01-06-2021 #4
My Engraving and Micro-Machining Solution
By magicniner in forum Machine DiscussionReplies: 7Last Post: 16-04-2016, 07:19 PM -
Keeping micro step position
By routercnc in forum Motor Drivers & ControllersReplies: 7Last Post: 28-12-2015, 04:09 PM -
Web based micro-industries (CNC machines)?
By Fivetide in forum Machine DiscussionReplies: 11Last Post: 04-03-2013, 11:42 AM -
Micro lathe Zero backlash* conversion
By Jonathan in forum Lathes, Lathe Rebuilding & ConversionsReplies: 14Last Post: 22-09-2012, 10:56 PM -
BUILD LOG: Widgetmast micro mill
By HS93 in forum DIY Router Build LogsReplies: 0Last Post: 06-07-2010, 12:37 AM
